2801 with PVDM2-32 problem
Hello
I got an 2801 with a PVDM2-32 on slot 0 that its gave me this error %PVDM2-1-SIMM_UNKNOWN: PVDM2 in slot 0: PVDM SIMM in subslot/pvdm slot 0
what its the right IOS to support this PVDM2-32 Module ?
Its suppoorted by Cisco Router 2801 the pvdm2-32 module?
Any ideas ?
Norman Santana
System returned to ROM by reload at 03:57:43 UTC Sun May 9 2010
System image file is "flash:c2801-adventerprisek9-mz.124-25a.bin"
Cisco 2801 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FTX13088XAT
2 FastEthernet interfaces
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Hall of Fame Super Gold
Re: 2801 with PVDM2-32 problem
PVDM can be faulty, have it replaced.
Hi Norman,
PVDM2 modules are supported on ISR routers such as 2801s. IOS is not an issue here. Did you try installing the PVDM on another PVDM slot on the router? If it still fails to get recognized (check show diag or show inventory to verify), then its a bad PVDM and needs to be replaced. If it gets recognized in another slot, then its a bad slot. HTH.
Harmit.
-- Regards, Harmit.
I Change to slot 1 and give the same error when i do sh diag
PVDM Slot 1:
        No Card PVDM daughter card
        IDPROM FIELD FORMAT ERROR, index 0x0
        EEPROM format version 0
        EEPROM contents (hex):
          0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Any ideas?
Hi Norman,
Based on the output snip below:
PVDM Slot 1:
I would recommend having the PVDM replaced as it appears to be faulty. This is the last resort since reseating didnt help.
Harmit.
-- Regards, Harmit.
1599
