2801 won't recognize vic2-2fxs in show voice port summary
Hello I have a cisco 2801 router that does not recognize the fxs module. I don't know if this is the right place to ask , I am a bigginer in voice also.  If there is something else you need to know about the router please ask me
thank you in advance
Router#sh diag
VIC Slot 0:
        2nd generation - FXS Voice daughter card (2 port)
        Hardware Revision        : 3.1
        Top Assy. Part Number    : 800-21341-01
        Board Revision           : E0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC091445KS
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V
        Product (FRU) Number     : VIC2-2FXS=
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 01
          0x10: 42 45 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 30
          0x20: 39 31 34 34 35 4B 53 03 00 81 00 00 00 00 04 00
          0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Cisco 2801 (revision 5.0) with 360448K/32768K bytes of memory.
Processor board ID
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
125184K bytes of ATA CompactFlash (Read/Write)
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Router#sh voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/1          2      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/2          2      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Re: 2801 won't recognize vic2-2fxs in show voice port summary
do you have installed PVDM modul ?
if not, you have to FXO/FXS to work
2811#sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V06 , SN: FCZ12437060
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW         , VID: V01 , SN: FOC12387MT0
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation t
wo port FXS voice interface daughtercard"
PID: VIC2-2FXS         , VID: V01 , SN: FOC12134BU3
NAME: "2nd generation two port FXS voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation t
PID: VIC2-2FXS         , VID: V01 , SN: FOC12134CGY
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC2-1MFT-T1/E1
- 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC15285Q86
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 , SN: FOC1238496V
2811#
and dont forget to rate post if it helps
Hall of Fame Super Gold
You need PVDM2 modules for the voice port to work.
955
