2811 CME DSP Error with G.722 calls
i have a CME 8.6 (IOS 151-4.M2) and a Voip SIP Trunk. Behind i have some 7961 SCCP Phones. Everything is working fine but if i want to perform a G.722 Call to Externals its not working and i got an DSP Error:
%DSMP-3-DSPALARM: Alarm on DSP : status=0x0 message=0x0 text=N
And i know the other side supports G.722
Here is my config:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-64
voice-card 0
dspfarm
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 192.168.5.99 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register Transcode
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g722-64
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
shutdown
dial-peer voice 1401 voip
description *** from GW to SIP Trunk ***
translation-profile outgoing SIP-Outgoing
destination-pattern 0T
session protocol sipv2
session target dns:<removed>
session transport udp
voice-class codec 1
voice-class h323 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
telephony-service
no auto-reg-ephone
max-ephones 7
max-dn 10
ip source-address 192.168.5.99 port 2000
system message <removed>
cnf-file location flash:
load 7961 SCCP41.9-2-3S.loads
time-format 24
max-conferences 8 gain -6
moh chan.wav
multicast moh 239.1.1.30 port 16384
web admin system name cisco secret 5 <removed>
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 13 2012 00:18:31
Is there something missing in  the config?
Here is a sh inventory:
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 , SN: <removed>
Here is a SCCP ALL:
show sccp all
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
        IPv4 Address: 192.168.5.99
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.5.99, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
CCM Group Identifier: 1
Description: None
Binded Interface: None
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated Profile: 1, Registration Name: Transcode
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 5, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: IMMEDIATE, Switchback Method: IMMEDIATE
Switchback Interval: 5 sec, Switchback Timeout: 0 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total Video Conferencing Sessions: 0, Connections: 0
Total Video Transcoding Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
Statistic                  Count
Send queue enqueue error   0
Socket send error          0
Msgs discarded upon error  0
Please any help.
Jason
UPDATE:
i have added the commands
service phone g722CodecSupport 2
codec g722-64
to telephony-service and now it works. But i have noise echo if i talk. I mean i can hear me very noise in the handset. Any ideas?
Cheers
Jason
VIP Super Bronze
Can you send the output of the ff  command
show voice dsp group all and
show voice dsp capabilities slot 0 dsp 1
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Following is output of command in your comment.
P1-3845#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 28.3.8
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 4
  Transcoding channels allocated: 4
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 120, reserved credits: 0
    Signaling channels allocated: 4
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Group: FLEX_GROUP_XCODE, complexity: MEDIUM
    Shared credits: 0, reserved credits: 120
    Transcoding channels allocated: 0
dsp 2:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 0
dsp 3:
  Max credits: 240
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 240
    Codec: CONF_G722, maximum participants: 8
    Sessions per dsp: 2
dsp 4:
  Max credits: 240
    Sessions per dsp: 2
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
  0 DSP resource allocation failure
P1-3845# show voice dsp capabilities slot 0 dsp 1
DSP Type: C5510 -16
Card 0 DSP id 1 Capabilities:
    Credits   240 ,  G711Credits 15,  HC Credits  40,  MC Credits  30,
    FC Channel  16,  HC Channel  6 ,  MC Channel  8 ,
    Conference 8-party credits:
     G711  30 ,  G729  120,  G722  120,  ILBC  240
Secure Credits:
   Sec LC Xcode  30,     Sec HC Xcode  80,
   Sec MC Xcode  60,     Sec LC UNIV Xcode  30,
   Sec HC UNIV Xcode  80,Sec MC UNIV Xcode  60,
   Sec G729 conf 120,    Sec G722 conf 240,     Sec ILBC conf 240,
   Sec G711 conf 60 ,
Max Conference Parties per DSP:
    G711 64,  G729 16,  G722 16,  ILBC 8 ,
    Sec G711 32,  Sec G729 16,
    Sec G722 8   Sec ILBC 8 ,
Voice Channels:
    g711perdsp = 16,  g726perdsp = 8 , g729perdsp = 6 , g729aperdsp = 8 ,
    g723perdsp = 6 ,  g728perdsp = 6 , g711_5msperdsp = 14, gsmamrnbperdsp = 6 ,
    ilbcperdsp = 6 ,  isacperdsp = 3 , modemrelayperdsp = 6 ,
    g72264Perdsp = 8 , h324perdsp = 5 ,
    m_f_thruperdsp = 16, faxrelayperdsp = 8 ,
    maxchperdsp = 16, minchperdsp = 3 ,
    srtp_maxchperdsp = 10, srtp_minchperdsp = 6 , faxrelay_srtp_perdsp = 8 ,
    g711_srtp_perdsp = 10, g729_srtp_perdsp = 6 , g729a_srtp_perdsp = 8
    gnx64_srtp_perdsp = 10
Silver
Hi Jason,
I also had the same issue with IOS 15.1, replaced it with 15.2.3T and the issue was fixed.
I think 15.3.1T was released last month, please check it out.
espereir
I have experienced same issue on Cisco3845 IOS 151-4.M2,
but after replacing IOS into 151-4.M5, the issue was disappeared.
Please try it.
798
