2811 HWIC 4 ESW
Hello All,
I have a Cisco 2811 running IOS adventerprisek9-mz.12.4-15.T and a
HWIC-4ESW POE installed. When I plug in a 7960 phone it does not power up....thoughts please
Hall of Fame Super Gold
Re: 2811 HWIC 4 ESW
Do you have the POE PS ? "show env" to know.
Re: 2811 HWIC 4 ESW
Yes, I do
Re: 2811 HWIC 4 ESW
Do you have power inline under interface? Beside that I'd to see "show diag" and "show env".
Re: 2811 HWIC 4 ESW
Can you please paste the show diag output and cross verify if you see "ILPM-4=" part number in that output.
Also check if the power supply which you have is "AC-IP".
-> Sushil
Re: 2811 HWIC 4 ESW
If you have the ILPM module for the HWIC and a POE enabled power supply in the router - make sure you have the cable that runs from the poe supply to the motherboard.
HTH.
Re: 2811 HWIC 4 ESW
Likely power supply is not AC-IP model.
322
