Community Member
2811 HWIC-4ESW-POE does not get inline power with PWR-2811-AC-IP
This seesms to be a common problem for users installing the PWR-2811-AC-IP to provide inline power to the HWIC-4ESW-POE, but I can't seem to find a solution to my own situation.  I have both of these installed in a 2811 and I can't not get inline power to my phones.  I would be grateful if someone could help.  After installing the power unit, do I need to run a command for inline power to work?  I noticed that the PWR-2811-AC-IP is identical in appearance to the power unit I replaced it with.  Are there any other connections besides the one to the motherboard that need to be done?
P1-BR2-VG#show diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:20:41 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC11524YD6
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-04
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20071227
        Chassis Serial Number    : FTX1203A3AE
        Chassis MAC Address      : 001e.7a5e.e7d8
        MAC Address block size   : 24
        CLEI Code                : COM7R00ARA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-05
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 31 35 32 34 59 44 36 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 43 3B C2 8B 46 54 58 31 32 30 33
          0x40: 41 33 41 45 C3 06 00 1E 7A 5E E7 D8 43 00 18 C6
          0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC12021YR0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
        Version Identifier       : V01
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 30 32
          0x20: 31 59 52 30 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 3.2
        Part Number              : 73-8539-04
        Board Revision           : A0
        Fab Version              : 03
        PCB Serial Number        : FOC09373S77
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-32
        Version Identifier       : NA
          0x00: 04 FF 40 03 EE 41 03 02 82 49 21 5B 04 42 41 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 39 33 37
          0x20: 33 53 37 37 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 33 32 89 4E 41 20 20 D9 02
        WIC Slot 0:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC130720NQ
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 33 30 37 32 30 4E 51 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        WIC Slot 1:
        FT1 PMC4351
        Hardware Revision        : 1.2
        PCB Serial Number        : FOC11520URW
        Part Number              : 73-8346-05
        Board Revision           : A0
        RMA History              : 00
        Deviation Number         : 0-0
        Product (FRU) Number     : WIC-1DSU-T1-V2
        Top Assy. Part Number    : 800-22193-03
        CLEI Code                : IPUIAPRRAA
          0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 31 35
          0x10: 32 30 55 52 57 82 49 20 9A 05 42 41 30 03 00 81
          0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
          0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
          0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
          0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        4 Port FE Switch
        Base MAC Address         : 0019.2fe6.b1ce
        MAC Address block size   : 4
        PCB Serial Number        : FOC103531CQ
        Hardware Revision        : 5.1
        Part Number              : 73-8474-05
        Board Revision           : B0
        Top Assy. Part Number    : 800-24193-01
        Fab Version              : 05
        CLEI Code                : IPUIAE0RAA
        RMA History              : 00
        Product (FRU) Number     : HWIC-4ESW
        Version Identifier       : VN/A
        Connector Type           : 01
          0x00: 04 FF CF 06 00 19 2F E6 B1 CE 43 00 04 C1 8B 46
          0x10: 4F 43 31 30 33 35 33 31 43 51 40 00 56 41 05 01
          0x20: 82 49 21 1A 05 42 42 30 C0 46 03 20 00 5E 81 01
          0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 45 30
          0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
          0x50: 49 43 2D 34 45 53 57 89 56 4E 2F 41 D9 02 C1 40
          0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        4-Port HWIC-ESW Power Daughter Card:
        Hardware Revision        : 3.0
        Part Number              : 73-8476-03
        Board Revision           : A0
        Fab Version              : 03
        PCB Serial Number        : FOC10353NXA
        RMA History              : 00
        Product (FRU) Number     : ILPM-4
        CLEI Code                : IPUPAAKAAA
          0x00: 04 FF 40 00 57 41 03 00 82 49 21 1C 03 42 41 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 30 33 35
          0x20: 33 4E 58 41 03 00 81 00 00 00 00 04 00 CB 86 49
          0x30: 4C 50 4D 2D 34 89 56 4E 2F 41 C6 8A 49 50 55 50
          0x40: 41 41 4B 41 41 41 FF FF FF FF FF FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 9F C8
AIM Module in slot: 0
Service Engine AIM: 0
        Top Assy. Part Number    : 800-20063-06
        Board Revision           : B0
        Deviation Number         : 93519
        Fab Version              : 05
        PCB Serial Number        : FOC11525S7B
        RMA History              : 00
        Product (FRU) Number     : AIM-CUE
        Version Identifier       : V03
          0x00: 04 FF 40 03 8E 41 01 00 C0 46 03 20 00 4E 5F 06
          0x10: 42 42 30 88 00 01 6D 4F 02 05 C1 8B 46 4F 43 31
          0x20: 31 35 32 35 53 37 42 03 00 81 00 00 00 00 04 00
          0x30: CB 87 41 49 4D 2D 43 55 45 89 56 30 33 20 FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
P1-BR2-VG#show envi
Main Power Supply is AC
Fan 1 OK
Fan 2 OK
Fan 3 OK
Fan Speed : Normal
System Temperature: 28 Celsius (normal)
Environmental information last updated 00:00:14 ago
P1-BR2-VG#show version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
P1-BR2-VG uptime is 21 minutes
System image file is "flash:c2800nm-ipvoicek9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FTX1203A3AE
6 FastEthernet interfaces
5 Serial interfaces
1 terminal line
2 Channelized/Clear E1/PRI ports
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
1982232K bytes of ATA CompactFlash (Read/Write)
P1-BR2-VG#
1 ACCEPTED SOLUTION
Super Bronze
Re: 2811 HWIC-4ESW-POE does not get inline power with PWR-2811-A
See this page:
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1161133
The Inline Power PSU should have a secondary connector in it which you need to cable in as indicated.
Maybe if you don't do that, it doesn't get identified...
If you don't have the secondary connectory, I guess you have the incorrect part.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hall of Fame Super Gold
You do not have PWR-2811-AC-IP, but just a regulat PS AC. Show env is telling you that also.
Community Member
P, what should the "show inv" show if the power unit were correct?  This power unit came in a Cisco box sealed at the factory, hard to believe it's not the right one, but I can't fund any model number on it.  The power unit that was pulled from the router doesn't have one either.
Super Bronze
See this page:
Aaron
Community Member
Yup, that's the problem.  Thanks, Aaron.
Super Bronze
No problem.
Hey Guys,
I know this thread is old but I am having the same issue and it appears that I am missing the ILP Connector as well, how can I go about getting a couple of these cables?
Community Member
Thank youuuuu!!!
Thank youuuuu!!!
5106
