2811 PRI D-Channel Support
I have two PRI's on a Nortel where the configuration is 46B + 2D; where there is an active D-channel and a backup. I want to swing this over CUCM 7.0 on 2811 router/gateway. Does the Cisco support a primary and backup D-channel?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 2811 PRI D-Channel Support
Yes, that is called NFAS. You will need to use H.323, as MGCP doesn't support that.
Great - thanks....I just checked out a NFAS configuration bulletin.
You're welcome. Please remember to rate useful posts with the scrollbox below.
186
