Community Member
2811 register with Sip Provider
Hi all,
I'm facing a strange issue with SIP provider registration.
Here is my sip config on the gw:
sip-ua
credentials username vgtestsimac password XXXXXX realm voipGATE
authentication username vgtestsimac password XXXXXX realm voipGATE
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 10
timers trying 1000
timers connect 100
timers connection aging 30
timers hold 120
timers register 1000
mwi-server dns:register.voipgate.com expires 3600 port 5060 transport udp unsolicited
registrar dns:register.voipgate.com expires 3600
sip-server dns:register.voipgate.com
offer call-hold conn-addr
host-registrar
permit hostname dns:register.voipgate.com
And I just want to know why the command "sh sip-ua register status" show that:
Voice_Gateway#sh sip-ua register status
Line peer expires(sec) registered
0.* 300 0 no
vgtestsimac -1 2603 yes
What is the line "0.*" and from where it come ?
It always send register packet to the SP and dunno how to remove it.
Anybody know ?
Thx
Fabian
1 ACCEPTED SOLUTION
Re: 2811 register with Sip Provider
Hi Fabian,
Check your pots dial peers, one of them probably has that as a destination-pattern.
You would want to configure something like this:
dial-peer voice 1 pots
destination-pattern 0.*
no sip-register
(Which by the way, should probably be 0T)
hth,
nick
Hi Fabian,
no sip-register
hth,
nick
Community Member
Thx.
That was it.
Fabian
Community Member
I am having the same problem , but I am not able to put the " no sip-register" under may dial-peer
I have a version 12.4 3825 Cisco ROuter
You may need a 12.4T release like 12.4(20)T3 for this command to be used.
-nick
Community Member
This is what i have
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
That's the rommon version.
224
