Community Member
2811 Router Caller ID issue
Dear all,
We configured TCL AA on to the 2811 router and registered the GW in call manager as H323 GW. We have telephone lines connected to FXO ports of the router. We recieve the call from PSTN and auto attendant is played from router and can make call to the extns of the call manager. Issue is we are not getting the caller ID, instead we are getting 4999 displayed on ip phone extns. Any config to enable caller ID from PSTN?
Find the config of the rut:
service jazirah flash://its-CISCO.
param operator 1225
paramspace english language en
paramspace english index 0
paramspace english location flash://
paramspace english prefix en
param aa-pilot 4999
dial-peer voice 4999 voip
service nicknetaa
destination-pattern 4999
session target ipv4:
incoming called-number 4999
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 cptone SA
 timeouts call-disconnect 1
 timeouts wait-release 2
 timing hookflash-out 50
 connection plar opx 4999
 caller-id enable
dial-peer voice 1000 voip
 destination-pattern ....
 codec g711ulaw
 no vad
Thanks & Regards,
M.Mohamed Raffiudeen...
Do you get the Caller-ID okay
Do you get the Caller-ID okay if you just bypass the script?
Hello , Can you please make
Hello ,
Can you please make some test call and collect below debugs
Debug vpm signal
Debug vtsp all
Nadeem ahmed
Br, Nadeem Please rate all useful post.
