2811 router configuration for SIP fall back when CCM4.1 down
I have a 2811 router with 2 E1 Pri and connected to a 4.1 CCM.
My understanding is that the link between CCM and the PRI is direct through the binding below
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
thus I have the feeling that the following is useless :
dial-peer voice 1 pots
service mgcpapp
direct-inward-dial
port 0/0/0:15
forward-digits all
BUT, in case the MGCP link with ccm is lost, I would like all incoming calls on E1 be forwarded to a SIP trunk
directly attached to the 2811 (and not to the CCM).
is this possible ?
thank you.
1 REPLY
Green
Normal working.
CUCM ----MGCP----2811--E1
For the E1 pri the dial peers are ignored under MGCP
All call control is backhauled to CUCM vis MGCP
Fall back when MGCP fails.
E1---2811---SIP
You loose the MGCP backhaul and call control is handed back to the dial peers.
You need to add
application
global
service alternate Default
description *** FOR INCOMING CALL MATCHING ***
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 11 voip
description *** SIP FALLBACK DIAL PEER ***
preference 1
destination-pattern 81....
voice-class codec 1
session protocol sipv2
session target ipv4:10.182.182.12
dtmf-relay sip-notify rtp-nte
ip qos dscp ef media
ip qos dscp cs3 sig
no vad
You will need to change this use your numbering scheme.
I dont know you need voice translations etc to change the numbers.
Mine shows that incoming call would be for 6 digits starting 81
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
235
