2811 w/ VIC2-FXO answers but doesn't route call to DN on CUCM 8.x
A 2811 has been added to a CUCM 8.x cluster.  The 2811 has a VIC2-4FXO card where 4 POTS lines will terminate once in production.  In the meantime, during the provisioing/lab phase, an FXS port from a VG was connected to port 0/1/0 of the VIC2-4FXO card to 'simulate' an inbound call.  In the CUCM, DN 4001 (on an IP phone) was added as the Attendant DN for testing.  All 4 ports on the 2811 are registered in the CUCM, but when a call is made to the line that is 'acting' as the POTS line, the call will not show up on DN 4001 - all I get is the following CUCM error message playback:  "the call cannot be completed as dialed, please consult your directory and call again or ask your operator for assistance, this is a recording."  The show run on the 2811 is posted below.  The recording is the standard CUCM message that plays when you dial an unreachable telephone number.  Please assist with any missing config - Thank you!!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.13 17:25:26 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Username: <removed>
Password:
2811001#show run
Building configuration...
Current configuration : 3558 bytes
version 12.3
no service pad
service password-encryption
hostname 2811_001
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable <removed>
username <removed>
clock timezone PST -8
clock summer-time DST recurring
no aaa new-model
no ip subnet-zero
ip cef
no ip domain lookup
no ftp-server write-enable
voice-card 0
no dspfarm
voice rtp send-recv
ccm-manager redundant-host 10.10.10.1
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.10.2 10.10.10.1
ccm-manager config
interface Loopback1
no ip address
interface FastEthernet0/0
description IPT
ip address 10.10.11.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description lab
ip address 10.10.10.10 255.255.255.0
duplex auto
speed auto
ip default-gateway 10.10.10.250
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.250
ip http server
ip http authentication local
access-list 1 permit 10.10.11.0
access-list 1 permit 0.0.0.0 255.255.255.0
control-plane
voice-port 0/1/0
timing hookflash-out 50
description POTS hunt 1
voice-port 0/1/1
description POTS hunt 2
voice-port 0/1/2
description POTS hunt 3
voice-port 0/1/3
description POTS hunt 4
mgcp
mgcp call-agent 10.10.10.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999010 pots
application mgcpapp
port 0/1/0
dial-peer voice 1 pots
application mgcpapp
port 0/1/0
dial-peer voice 2 pots
port 0/1/1
dial-peer voice 3 pots
port 0/1/2
dial-peer voice 4 pots
port 0/1/3
dial-peer voice 999011 pots
application mgcpapp
port 0/1/1
dial-peer voice 999012 pots
application mgcpapp
port 0/1/2
dial-peer voice 999013 pots
application mgcpapp
port 0/1/3
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
transport output telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
2811_001#exit
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride...  the salvation of man."
- unknown
Re:2811 w/ VIC2-FXO answers but doesn't route call to DN on CUCM
Hi George,
Can you capture the output of the following command.
Debug mgcp packet
Debug vpm signal
Debug VoIP vtsp all
Kevin
Sent from Cisco Technical Support Android Appreciate
Secondly you would need to bind the interface too. For example :
Mgcp bind media source interface gig 0 /0
Mgcp bind control source interface gig 0/0
Kindly rate the post accordingly.
Kevin
184
