2821 isr
My tech has left and we are trying to add a phone number to an existing system. Verizon ported a new phone number to an existing T1 line. How do i add that number to the callmanager? where can i see the numbers that are already installed?
1 ACCEPTED SOLUTION
Re: 2821 isr
You should see a link on each post that says "Rate this post" with a Submit button beside it. I'll be glad to try to answer any questions that I can here on the forum. If you would like additional help, feel free to shoot me an email at the address in my profile.
Are 6500/5500 going to an auto attendant or IVR script or to a live person? Either way, they can be routed to the appropriate scipt/person. You can enforce the transfer rule you mentioned with partitions and calling search spaces.
Brandon
Re: 2821 isr
Are you using MGCP or H.323 to control the T1? If you're not sure, please post your config from the 2821.
Brandon
Re: 2821 isr
i think this is it
Re: 2821 isr
This is an H.323 gateway. From the following dial peer, it looks like the telco may just be sending you 4 digits. Do you know if that is correct?
dial-peer voice 800 voip
tone ringback alert-no-PI
description calls to CCM
destination-pattern [56]...
session target ipv4:192.168.7.245
dtmf-relay h245-alphanumeric
codec g711ulaw
If that's the case, you could create another dial peer with the last 4 of the new number assuming it does not overlap with an existing number, such as:
dial-peer voice 801 voip
destination-pattern 1234
codec g711ulaw
In Callmanger, 1234 (in the dial peer above) will need to match a DN or match a translation pattern which translates the number to a valid DN.
Hope this helps. If so, please rate the post.
Brandon
Re: 2821 isr
do you know where in callmanager i would establish this? The new line is a pots line does that matter and if so do i need to configure it like
existing
dial-peer voice 107 pots
description POTs phone 5924
destination-pattern 5924
port 2/0/7
new
dial-peer voice 108 pots
description POTs phone 5525
destination-pattern 5525
port 2/0/8
after i make the change do i need to apply the changes or will it reread the config file?
Re: 2821 isr
This would be correct. You do not need to apply the changes. They will take affect immediately. In Callmanager, you will need a route pattern that points to this gateway. If the new number is in the same range, it may already be in place. For examples, you may have a route pattern 5XXX that points to this gateway which would include all numbers 5000 - 5999. If not, you will need to create a new route pattern.
Brandon
Re: 2821 isr
you have been very helpful. Are you available for phone support should i need it? if so what are your rates?
is there a way to have two main phone numbers. say 6500 for one company and 5500 for another. when the system sees 6500 it answers company 1 and when it sees 5500 it answers company 2? The calls can only be forwarded to the extensions with in the companies 6500 to 6501,02,03.... 5500 to 5501,5502,...
thanks
where do i go to rate?
Re: 2821 isr
Brandon
240
