Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
2821 SIP
Got a good one here. Customer is looking at using the 2821 router. They are being delivered an ethernet pipe from a co-location facility. It is carrying SIP G.729 traffic. They want to take this traffic and convert to T1 TDM for a server locally. Can CCME do this? Kind of a reverse router
Thx
Dwight
I am wrong thinking that the IOS feature set with Session Border Control will do this?
1 ACCEPTED SOLUTION
Re: 2821 SIP
Yes, an IOS feature set with Session Border Gateway - aka IPIP Gateway - will do this job.
The IOS will terminate the SIP signalling, which is then converted to H.323 to talk to the T1 TDM. There are three issues that you need to think about in configuring the DSPs:
(a) The number of voice channels. Each PVDM2-XX will cope with XX/2 number of G729a calls.
(b) The number of calls simultaneously on hold/transfer - these will require an MTP configured.
(c) The number of simultaneous voice conferences - these will require a XCoder.
If you use the DSP config tool these should be calculated for you automatically.
To enable the gateway function, you need to enter
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
you will then need a dial peer
dial-peer voice 998 voip
destination-pattern (whatever)
session-protocol sipv2
session-target ipv4:
dtmf-relay rtp-nte
[dial peer defaults to g729]
you may also need to register to the SP
sip-ua
authentication username password realm
You need to be careful to test all scenarios -e.g. hold, conference, fax etc. Be aware that Music On Hold down G.729 sounds pretty terrible, and you have to transcode this on CME as there is no option to record a MOH in native G.729.
Re: 2821 SIP
hi Dwight,
well i think its a job of DSP to convert from IP to TDM so no matter what you have there as long as they have DSP ther shouldnt be any issues.
Re: 2821 SIP
So as long as I add a PVDM module to the router I should be OK?
Re: 2821 SIP
voice service voip
dtmf-relay rtp-nte
sip-ua
Re: 2821 SIP
Thanks for the great information.
DT
Re: 2821 SIP
Is there a way to make the IPIP GW proxy the registration to another server?
326
