2821 Voice Gateway
I need to add more DSP resources to my voicegateway. I currently have 1 PVDMII 32 with 2 16 channel dsp ( I am guessing on the motherboard). My question is can I just order another PVDMII 32 and add this to my mother board? Or do I need some type of NM to do this?
dfwdls-2821-01#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 8.4.1
Max signal/voice channel: 16/16
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 7
Voice channels allocated: 0
Credits used: 0
dsp 2:
Max credits: 240
Signaling channels allocated: 16
Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
dsp 1:
Max credits: 240
Credits used: 0
dsp 2:
Max credits: 240
Credits used: 0
DSP groups on slot 2:
This command is not applicable to slot 2
0 DSP resource allocation failure
dfwdls-2821-01#sh inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V04, SN:
NAME: "One port T1 voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "On
e port T1 voice interface daughtercard"
PID: VWIC-1MFT-T1= , VID: 1.0, SN:
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot
2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SI
MM with Two DSPs"
PID: PVDM2-32 , VID: NA , SN:
1 ACCEPTED SOLUTION
Re: 2821 Voice Gateway
The ISR 2821 has three onboard PVDM slots, therefore it is possible to add a 2nd or 3rd PVDM2-32 if required.
Your 'show inv' only indicates the single PVDM, therefore you should be able to add two additional PVDMs
Hope this helps.
Allan.
Pls rate helpful posts.
Hope this helps.
Allan.
The 2821 has 3 PVDM2 onboard slots. You should be able to add another PVDM2 DSP without an NM. This DSP calculator is very helpful.
http://www.cisco.com/cgi-bin/Support/DSP/dsp-calc.pl
222
