2900 ISR compatibility CUCM 6.X
hauchinango
Level 3
Level 3
Does anyone have a doc on comptability matrix for the 2900 routers?  We are starting to order these for our remote sites, but we are sitting at 6.1.3.
Brandon Buffin
If you are looking to run MGCP on the 2900 ISR, I think you may be out of luck.  My 6.1.4 doesn' t recoginize a 2900 series type for MGCP.  It will probably be available in a patch sooner or later, but I don't know when.
However, if you want to run H.323, you should be fine.  CUCM doesn't care what hardware is running the gateway if it's using the H.323 protocol.
Chris
Brandon Buffin
Looks a minimum of 6.1.5 is required for the 2900 series.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope this helps.
Brandon
Thanks, yeah, looks like 6.1.5 is going to be my route.  It was just released a week ago or so, so I will be
holding off for a bit.
Thanks again
