2901 ISDN no route to destination error - UPDATE
I posted this a few days ago but have investigated it a bit further and came to a different conclusion.
I have the following configuration:
Alcatel ---> 2901 (3xxx) <-----------------Fibre IP  LINK---------------> 2901 (in Data Centre) ------->Primary IP PBX
                Backup IP LINK
Alcatel ---> 2600 (2xxx) <-----------------Fibre IP  LINK---------------> 2600 (in Data Centre) ------->Secondary IP  PBX
Above shows the links in their basic form (it's a lot more complicated in reality).
As it stands at the moment -   All calls originating from a 3xxx number  come from the primary PBX and via the 2901 routers.  Any calls to a 3xxx  number use the same link.
The 2xxx link is purely there as a backup/failover.
There are no day to day problems in terms of routing internal to external, digital/analog (from Alcatel) to IP and vice versa.
The problem only arises when I create a fault condition.
If I shutdown the IP port on the 2901 at the Alcatel end this simulates a fibre fault, remote end fault etc
Calls from an IP phone to an Alcatel extension (analog/digital) route fine down the 2600 route
Calls from an IP phone to an external number route down the 2600 route fine
Calls from an Analog and/or digital extension route up the 2600 route fine
Calls from external to a 3xxx number don't - They fail with a no route to destination message.
The 2901 router is set to try the primary route first, if that fails it  goes down another IP link to the 2600, it should then pass that up the  chain. Which is succeedes in doing for everything except external coming  in.
Running my own traces I see the call go as far as the first 2600 where  it then fails and I don't understand why - I would have thought it would  have treated it the same as a call going from an analog/digital  extension to an IP phone.  The only difference being  a longer CLID.
It must know that it's external or the Alcatel is handling it differently to internal calls but I'm completely stumped!
I also set the forward on an external number to a 2xxx number and this routed fine which proves to me that the router config is OK
I would appreciate some input from someone please!!
The call never seems to reach the 2600 in the Data Centre so here's a ccapi and a dialpeer trace from the 2600 at the Alcatel along with it's config:
I have replaced my CLID with 123456789 for security reasons
ccapi:
2600_A_ALCATEL#
00:04:17: //-1/34F0EC0A9C84/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=10.11.0.55
   ----- ccCallInfo IE subfields -----
   cisco-ani=123456789
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=3001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
00:04:17: //-1/34F0EC0A9C84/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x84498E4C, Call Info(
   Calling Number=123456789(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=3001(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1
00:04:17: //1/34F0EC0A9C84/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=123456789(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=3001(TON=Unknown, NPI=Unknown))
00:04:17: //1/34F0EC0A9C84/CCAPI/cc_process_call_setup_ind:
   Event=0x847C3F00
00:04:17: //1/34F0EC0A9C84/CCAPI/ccCallSetContext:
   Context=0x83AC16CC
   >>>>CCAPI handed cid 1 with tag 0 to app "_ManagedAppProcess_Default"
00:04:17: //1/34F0EC0A9C84/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
2600_A_ALCATEL#llDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
00:04:17: //1/34F0EC0A9C84/CCAPI/ccCallDisconnect:
   Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
00:04:17: //1/34F0EC0A9C84/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
00:04:17: //1/34F0EC0A9C84/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x84498E4C, Tag=0x0, Call Id=1,
   Call Entry(Disconnect Cause=3, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
00:04:17: //-1/xxxxxxxxxxxx/CCAPI/ccTimerInit:
   ccTimerctx - 0x83A442D8
2600_A_ALCATEL#
dialpeer
voip dialpeer all debugging is on
2600_A_ALCATEL#
00:06:03: //-1/74FA5B839C85/DPM/dpAssociateIncomingPeerCore:
   Calling Number=123456789, Called Number=3001, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=3001
00:06:03: //-1/74FA5B839C85/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
00:06:03: //-1/74FA5B839C85/DPM/dpMatchCore:
   Dial String=3001, Expanded String=3001, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
00:06:03: //-1/74FA5B839C85/DPM/dpMatchPeertype:exit@5398
   Match Rule=DP_MATCH_ANSWER; Calling Number=123456789
   Dial String=, Expanded String=, Calling Number=123456789T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=123456789
   Result=-1
   Result=NO_MATCH(-1) After All Match Rules Attempt
00:06:03: //-1/74FA5B839C85/DPM/dpAssociateIncomingPeerSPI:exit@5932
   Result=-1
   Result=-1
   Match Rule=DP
2600_A_ALCATEL#_MATCH_ORIGINATE; Calling Number=123456789
   Result=-1
00:06:03: //-1/74FA5B839C85/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=3001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=3001
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
00:06:03: //-1/74FA5B839C85/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2 Is Matched
   Result=Success(0) after DP_MATCH_DEST
00:06:03: //-1/74FA5B839C85/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2
2600_A_ALCATEL#
config
Building configuration...
Current configuration : 2306 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 2600_A_ALCATEL
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
fax protocol pass-through g711alaw
h323
  h225 timeout setup 2
voice class codec 1
codec preference 1 g711alaw
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet0/0
ip address 10.11.0.50 255.0.0.0
duplex auto
speed auto
no cdp enable
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T203 30000
isdn timer T310 60000
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
router rip
network 10.0.0.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
no cdp run
control-plane
voice-port 1/0:15
dial-peer voice 5 pots
destination-pattern 9.+
direct-inward-dial
port 1/0:15
prefix 9
dial-peer voice 6 pots
destination-pattern 4...
direct-inward-dial
port 1/0:15
prefix 4
dial-peer voice 7 pots
destination-pattern 5...
direct-inward-dial
port 1/0:15
prefix 5
dial-peer voice 8 pots
destination-pattern 7...
direct-inward-dial
port 1/0:15
prefix 7
dial-peer voice 1 voip
destination-pattern 20..
voice-class codec 1
session target ipv4:10.11.0.51
session transport udp
dial-peer voice 2 voip
destination-pattern 30..
voice-class codec 1
fax-relay ecm disable
sip-ua
retry invite 2
timers trying 150
line con 0
exec-timeout 0 0
password 7
logging synchronous
login
line aux 0
line vty 0 4
password 7
logging synchronous
login
end
Message was edited by: John Campbell
Just wondering if anyone has any thoughts on my problem? - It's really starting to bug me now!!!
Green
John,
The Campbells are coming...
I think this shows that this call could not
match in incoming dial peer.
Just for a test can you add a test dial peer
dial-peer voice 1111 pots
desc *** TESTING ***
incoming called number .
direct-inward-dial
port 1/0:15
Retest.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
If I had your dialpeer this will send the call out the digital interface back to the Alcatel? - Potentially creating a loop?
Just to mention that my diagram looks like 2 separate systems but the Alcatel is one system with 2 E1 outputs.  Another point to mention is that the Alcatel has the direct connection to BT (external link in)
It seems strange to me that the traces show it being successful in matching various dial-peers.  As mentioned before routing internal calls through the same channels works fine, its only external to internal.
I added what you suggested with no change.  These are the traces:
ccapi:
2600_A_ALCATEL#
11:33:00: //-1/6D0B943B9C90/DPM/dpAssociateIncomingPeerCore:
11:33:00: //-1/6D0B943B9C90/DPM/dpMatchPeertype:
11:33:00: //-1/6D0B943B9C90/DPM/dpMatchCore:
11:33:00: //-1/6D0B943B9C90/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1111 Is Matched
11:33:00: //-1/6D0B943B9C90/DPM/dpMatchPeertype:exit@5398
   Result=-1
   Result=-1
11:33:00: //-1/6D0B943B9C90/DPM/dpAssociateIncomingPeerSPI:exit@5932
2600_A_ALCATEL#EER_TYPE_VOICE,
   Result=-1
   Result=-1
11:33:00: //-1/6D0B943B9C90/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=123456789
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=3001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
11:33:00: //-1/6D0B943B9C90/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3
11:33:00: //3/6D0B943B9C90/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
11:33:00: //3/6D0B943B9C90/CCAPI/cc_process_call_setup_ind:
   Event=0x847C3F00
11:33:00: //3/6D0B943B9C90/CCAPI/ccCallSetContext:
   Context=0x83AC2F8C
   >>>>CCAPI handed cid 3 with tag 0 to app "_ManagedAppProcess_Default"
11:33:00: //3/6D0B943B9C90/CCAPI/ccCallProceeding:
11:33:00: //-1/6D0B943B9C90/DPM/dpMatchPeersCore:
2600_A_ALCATEL#M/MatchNextPeer:
11:33:00: //-1/6D0B943B9C90/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
11:33:00: //3/6D0B943B9C90/CCAPI/ccCallDisconnect:
11:33:00: //3/6D0B943B9C90/CCAPI/cc_api_get_transfer_info:
11:33:00: //3/6D0B943B9C90/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x84498E4C, Tag=0x0, Call Id=3,
2600_A_ALCATEL#
2600_A_ALCATEL#
11:36:37: //-1/EE29C7B79C91/DPM/dpAssociateIncomingPeerCore:
11:36:37: //-1/EE29C7B79C91/DPM/dpMatchPeertype:
11:36:37: //-1/EE29C7B79C91/DPM/dpMatchCore:
11:36:37: //-1/EE29C7B79C91/DPM/MatchNextPeer:
11:36:37: //-1/EE29C7B79C91/DPM/dpMatchPeertype:exit@5398
   Result=-1
   Result=-1
11:36:37: //-1/EE29C7B79C91/DPM/dpAssociateIncomingPeerSPI:exit@5932
   Result=-1
   Result=-1
11:36:37: //-1/EE29C7B79C91/DPM/dpMatchPeersCore:
2600_A_ALCATEL#Result=Success(0); Outgoing Dial-peer=2 Is Matched
11:36:37: //-1/EE29C7B79C91/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
2600_A_ALCATEL#
2600_A_ALCATEL#
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   cisco-ani=123456789
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=3001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Set Up Event Sent;
   Event=0x847C3F00
   Context=0x83AC2F8C
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
2600_A_ALCATEL#
dialpeer
2600_A_ALCATEL#
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
2600_A_ALCATEL#
1219
