Community Member
2901 with EHWIC-D-8ESG-P 8 port card, phones do not get to voice vlan
I have a 2901 router with a EHWIC-D-8ESG-P card in it. I have configured a DHCP Pool for the voice vlan but the phones get an IP address from the data vlan. What am I doing wrong..,?
ip dhcp excluded-address 10.2.100.1 10.2.100.30
ip dhcp pool Phones
network 10.2.100.0 255.255.255.0
default-router 10.2.100.1
option 150 ip 10.0.100.10
interface GigabitEthernet0/3/0
switchport voice vlan 100
no ip address
interface GigabitEthernet0/3/1
no ip address
interface GigabitEthernet0/3/2
no ip address
interface GigabitEthernet0/3/3
no ip address
interface GigabitEthernet0/3/4
no ip address
interface GigabitEthernet0/3/5
no ip address
interface GigabitEthernet0/3/6
no ip address
interface GigabitEthernet0/3/7
no ip address
interface Vlan1
ip address 10.2.0.1 255.255.255.0
ip helper-address 10.0.0.5
interface Vlan100
ip address 10.2.100.1 255.255.255.0
Green
You have to configure these ports the old fashioned way.
If you want your phones to support both a VOICE VLAN ana
DATA VLAN try this
interface range giga 0/3/0 - 7
desc *** PORTS FOR PHONES & DATA ***
Switchport trunk encapsulation dot1q
Switchport mode trunk
Switchport trunk native vlan 1
Switchport voice vlan 100
Spanning-tree portfast trunk
no ip address
no shut
Give it a try
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hall of Fame Super Gold
Re: 2901 with EHWIC-D-8ESG-P 8 port card, phones do not get to v
That is the same finding I had on a 28xx years ago, phones werent getting an address at all. It drove me crazy for hours.
Green
Hi Paolo
I have been thinking about this again
I am not sure if he has to create the
VLANS under the vlan.dat aswell.
vlan data
vtp trans
vlan 100 name VOICE
vlan 1 name DATA
exit
Just in case it is needed
Alex
Community Member
No Go... Still having the same issue, thanks for the help...
Green
With a phone plugged in can
you post
show int vlan 100
Alex
Community Member
LeecoWI-Plant-2901#sh int vlan 100
Vlan100 is up, line protocol is up
  Hardware is EtherSVI, address is ccef.48c7.15db (bia ccef.48c7.15db)
  Internet address is 10.2.100.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 00:00:18, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     371 packets input, 43974 bytes, 0 no buffer
     Received 17 broadcasts (0 IP multicasts)
     2229 packets output, 336242 bytes, 0 underruns
     0 output errors, 1 interface resets
     0 unknown protocol drops
LeecoWI-Plant-2901#
Green
Sorry for the delay.
There always seemed to issues when using switch cards on routers
Can you issue the folowing commands
conf t
vtp mode trans
vlan 1
name DATA
vlan 100
name VOICE
end
Re check
Alex
Community Member
Ya these modules always have issues. I got the older modles to work by putting the in trunk mode but no luck here.
I tried this and no luck
conf t
vtp mode trans
vlan 1
name DATA
vlan 100
name VOICE
end
Green
When you boot a phone do you see it
configuring VLAN
What model of phon are you using.
Alex
978
