2901 with HWIC-4ESW-POE
jeremybrainard
I have a 2901 (config snippets below) with an HWIC-4ESW-POE in Slot 0.  I also have other switches down stream off of g0/1.  The problem is that I can not get network devices (phones or computers) to work when I plug them in to the HWIC-4ESW-POE in Slot 0.  They work fine when I plug them into an actual switch, but will not obtain an IP Address when plugged into the switch module that is in the router.  Eventually, these ports will be used for IP Phones and possibly an IP Camera.
I'm sure it's something simple, but it seems I've tried everything I can think of.  Thanks in advance!
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.100.50.0 10.100.50.99
ip dhcp excluded-address 10.100.10.0 10.100.10.99
ip dhcp pool LAN
   network 10.100.50.0 255.255.255.0
   update dns
   domain-name jeremysbrain.local
   default-router 10.100.50.1
   dns-server 10.100.50.1 8.8.8.8
   option 150 ip 10.100.10.1
ip dhcp pool VOICE
   network 10.100.10.0 255.255.255.0
   default-router 10.100.10.1
   dns-server 10.100.10.1 8.8.8.8
ip domain name jeremysbrain.local
vtp interface gi0/1
vtp version 2
redundancy
interface GigabitEthernet0/0
description WAN - Connected to cable modem
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
description VOICE
encapsulation dot1Q 10
ip address 10.100.10.1 255.255.255.0
ip helper-address 10.100.100.1
interface GigabitEthernet0/1.50
description DATA
encapsulation dot1Q 50
ip address 10.100.50.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.100
description MANAGMENT
encapsulation dot1Q 100
ip address 10.100.100.1 255.255.255.0
interface FastEthernet0/3/0
switchport voice vlan 10
interface FastEthernet0/3/1
shutdown
interface FastEthernet0/3/2
shutdown
interface FastEthernet0/3/3
shutdown
interface Vlan1
ip nat inside
router eigrp 100
network 10.100.0.0 0.0.255.255
ip default-gateway 10.100.10.1
ip forward-protocol nd
ip dns server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip access-list extended NAT
permit ip 10.100.50.0 0.0.0.255 any
tftp-server flash:SDM_Backup
tftp-server flash:/cme/phones/7970-7971/apps70.8-5-4TH1-6.sbn alias apps70.8-5-4TH1-6.sbn
tftp-server flash:/cme/phones/7970-7971/cnu70.8-5-4TH1-6.sbn alias cnu70.8-5-4TH1-6.sbn
tftp-server flash:/cme/phones/7970-7971/cvm70sccp.8-5-4TH1-6.sbn alias cvm70sccp.8-5-4TH1-6.sbn
tftp-server flash:/cme/phones/7970-7971/dsp70.8-5-4TH1-6.sbn alias dsp70.8-5-4TH1-6.sbn
tftp-server flash:/cme/phones/7970-7971/jar70sccp.8-5-4TH1-6.sbn alias jar70sccp.8-5-4TH1-6.sbn
tftp-server flash:/cme/phones/7970-7971/SCCP70.8-5-4S.loads alias SCCP70.8-5-4S.loads
tftp-server flash:/cme/phones/7970-7971/term70.default.loads alias term70.default.loads
tftp-server flash:/cme/phones/7970-7971/term71.default.loads alias term71.default.loads
tftp-server flash:/cme/phones/7940-7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/cme/phones/7940-7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/cme/phones/7940-7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/cme/phones/7940-7960/P00308010200.sbn alias P00308010200.sbn
control-plane
gateway
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
max-ephones 24
max-dn 48
ip source-address 10.100.10.1 port 2000
auto assign 40 to 48
load 7960-7940 P00308010200.loads
load 7970 SCCP70.8-5-4S.loads
load 7971 SCCP70.8-5-4S.loads
time-zone 5
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 20 2010 12:06:24
ephone-dn  1  octo-line
number 2001
name Physical
ephone-dn  2  dual-line
number 2002
label Virtual
name Virtual
ephone  1
description CIPC on Physical PC
mac-address 001A.92DA.C66C
type CIPC
button  1:1
ephone  2
description Virtual
mac-address 000C.298D.4D41
type CIPC
button  1:2
ephone  100
description Test
mac-address 0030.94C2.D30F
type 7960
ntp master
ntp server 209.81.9.7
8 Replies 8
Brandon Buffin
I'm assuming you are plugging the computer/phone into 0/3/0 as the other ports appear to be shut down. Are VLANs 10 and 50 configured on this device? You can issue "show vlans" to check. Assuming the VLANs are configured, you will need to remove the subinterfaces for Gig0/1 and move this to an SVI config. You can see an example of the config at the link below.
http://www.cisco.rw/en/US/prod/collateral/routers/ps5853/prod_white_paper0900aecd8064c9f4.pdf
Basically, you will have:
interface Vlan10
ip nat inside
interface Vlan50
ip nat inside
Hope this helps.
Brandon
Got it...
Never used SVI configs before.  Is it similar to using Sub-Interfaces?
You were correct, I did have the VLAN's configured on the router, and I was using Fa0/3/0.
I've adjusted the interfaces (configs below), but I'm still not routing traffic through the router.  I can't even ping the switch that's plugged into Gi0/1 at IP Address 10.100.100.15.  What should I do with Gi0/1;  Does it need an IP Address?
The link you sent was helpful, but slightly cryptic in regards to routing traffic, and actually using SVI.
Thanks Again!
ip address dhcp
ip nat outside
duplex auto
speed auto
description LAN
ip nat inside
duplex auto
speed auto
switchport access vlan 50
shutdown
shutdown
interface Vlan10
description VOICE
ip helper-address 10.100.10.1
ip nat inside
interface Vlan50
description DATA
ip nat inside
Move the config for gig0/1 to the Vlan1 interface:
interface Vlan1
ip nat inside
Brandon
Am I still able to use Gi0/1 to connect to an external switch?  or does everything need to be plugged into the HWIC card in Slot 0?
Thanks Again
You can use gig0/1. You'll want to make it a trunk port if connecting to another switch:
interface gig0/1
switchport trunk native vlan 1
switchport mode trunk
Make sure the switch on the other side of the port is set to trunk as well.
Brandon
No Luck...  Unless I'm missing something, the Switchport command is unavaliable on Gi0/1.  Possibly because it's a L3 port?  G0/0 and G0/1 are built in to the router.
Sorry, my mistake. You can either configure the trunk on one of the 4ESW switch ports or reconfigure the subinterfaces such as:
ip unnumbered vlan 10
ip unnumbered vlan 50
ip unnumbered vlan 100
Hope this helps.
Brandon
I used the "ip unnumbered" structure as noted, and the ports on the 4ESW work perfectly.  The switch, a 2960 on Gi0/1 is not.  Is there any modifications I need to make to the configuration of the switch?
