2901 with VIC2-2FXO and Valcom paging system
Hello, I have a 2901 on 15.1(2)T with a VIC2-2FXO card connected to a Valcom V-2006A paging system on port 0/1/1.  I have CUCM configured to route the #20 pattern to the 2901 H.323 gateway.  The debugging output below indicates that the dialed pattern is being sent to the 2901 successfully, but the dial-peer does not appear to be working and I get an immediate fast busy signal.
Configuration:
voice-port 0/1/1
dial-peer voice 20 pots
 destination-pattern #20
 port 0/1/1
Debug output (calling number changed for privacy):
*Apr 10 20:50:10.636: //-1/003E27473800/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8655551212, Called Number=#20, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=#20
*Apr 10 20:50:10.636: //-1/003E27473800/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Apr 10 20:50:10.636: //-1/003E27473800/DPM/dpMatchCore:
   Dial String=#20, Expanded String=#20, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Apr 10 20:50:10.636: //-1/003E27473800/DPM/dpMatchPeertype:exit@5982
   Match Rule=DP_MATCH_ANSWER; Calling Number=8655551212
   Dial String=, Expanded String=, Calling Number=8655551212T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=8655551212
   Result=-1
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpAssociateIncomingPeerSPI:exit@6561
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpAssociateIncomingPeerCore:
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpMatchPeertype:
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpMatchCore:
   Result=-1
*Apr 10 20:50:10.640: //-1/003E27473800/DPM/dpMatchPeertype:exit@5982
   Result=-1
   Result=-1
*Apr 10 20:50:10.640: //-1/003E27473800/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3022077C; count=1
*Apr 10 20:50:10.640: //-1/003E27473800/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x320CE5CC
*Apr 10 20:50:10.640: //-1/003E27473800/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Apr 10 20:50:10.640: //-1/003E27473800/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x3022077C; count=1
This configuration is working perfectly well on a 2801 running 12.4(15)T7.
Any suggestions?
Everyone's tags (1)
try matching an inbound dial
try matching an inbound dial-peer for all calls...
This configuration:dial-peer
This configuration:
dial-peer voice 1 pots
 incoming called-number .
 port 0/1/1
Produces this debug output:
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpAssociateIncomingPeerCore:
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpMatchPeertype:
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpMatchCore:
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpMatchPeertype:exit@5982
   Result=-1
   Result=-1
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpMatchSafModulePlugin:
*Apr 11 18:15:48.787: //-1/00F3FBE04000/DPM/dpAssociateIncomingPeerSPI:exit@6561
*Apr 11 18:15:48.791: //-1/00F3FBE04000/DPM/dpMatchCore:
   Result=-1
*Apr 11 18:15:48.791: //-1/00F3FBE04000/DPM/dpMatchPeertype:exit@5982
*Apr 11 18:15:48.791: //-1/00F3FBE04000/DPM/dpAssociateIncomingPeerCore:
   Result=-1
*Apr 11 18:15:48.791: //-1/00F3FBE04000/DPM/dpMatchSafModulePlugin:
*Apr 11 18:15:48.791: //-1/00F3FBE04000/DPM/dpAssociateIncomingPeerSPI:exit@6561
*Apr 11 18:15:48.791: //-1/00F3FBE04000/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3022077C; count=1
*Apr 11 18:15:48.791: //-1/00F3FBE04000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x320CE788
*Apr 11 18:15:48.791: //-1/00F3FBE04000/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Apr 11 18:15:48.791: //-1/00F3FBE04000/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x3022077C; count=1
Were you able to resolve this
Were you able to resolve this issue? I'm running into the same problem with the same hardware.
Could you please elaborate
Could you please elaborate your issue?
regards
This configuration:
 destination-pattern .
 port 0/1/1
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpAssociateIncomingPeerCore:
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpMatchPeertype:
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpMatchCore:
   Result=-1
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpMatchPeertype:exit@5982
   Result=-1
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/MatchNextPeer:
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpMatchSafModulePlugin:
*Apr 11 18:18:58.555: //-1/00A63B524200/DPM/dpAssociateIncomingPeerSPI:exit@6561
   Result=-1
   Result=-1
*Apr 11 18:18:58.555: //-1/00A63B524200/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x30220674; count=1
*Apr 11 18:18:58.555: //-1/00A63B524200/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x320CDD20
*Apr 11 18:18:58.559: //-1/00A63B524200/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Apr 11 18:18:58.559: //-1/00A63B524200/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x30220674; count=1
*Apr 11 18:18:58.559: //-1/00A63B524200/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x30220674; count=1
*Apr 11 18:18:58.559: //-1/00A63B524200/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x320CDD20
Silver
Hello,Please post ( sh diag )
Please post ( sh diag ) command result from your h323 router. I doubt that there is something missing in DSP components.
285
