2911 Fax Server H323 Outbound not working but inbound is?
Hi I have a 2911 set up and cannt get a call onto the pstn. The calls hit the outboind line and fail with cause code 31.
Inbound calls work OK.
If i change to SIP they work.
If I hairpin a call back it works.
Does anyone have a sample config ?
My config below
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
card type e1 0 0
logging buffered 40960
no aaa new-model
clock timezone AEST 10 0
clock summer-time AEDT recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  session transport udp
  h245 tunnel disable
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
controller E1 0/0/0
pri-group timeslots 1-10,16
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.16.5.71 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.16.5.2
control-plane
voice-port 0/0/0:15
mgcp profile default
dial-peer voice 10 pots
description **prefix 0 outbound**
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
dial-peer voice 25 voip
description ** 935690.. toTEST **
destination-pattern 935690.
session target ipv4:10.240.16.80
incoming called-number .
voice-class codec 1
no vad
gatekeeper
shutdown
What is your inbound dial-peer?
Can you add the output of "debug voice ccapi inout"?
Regards.
Inbound dial peer is the voice 25 as above
*Mar 19 02:05:36.078: //-1/7ABC0ED929EC/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=10.240.16.80
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=00283376014
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar 19 02:05:36.078: //-1/7ABC0ED929EC/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x31565BAC, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Scree
ned, Presentation=Allowed),
   Called Number=00283376014(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T
RUE,
   Incoming Dial-peer=25, Progress Indication=NULL(0), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=34
*Mar 19 02:05:36.078: //-1/7ABC0ED929EC/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen
tation=Allowed)
*Mar 19 02:05:36.078: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 02:05:36.078: :cc_get_feature_vsa malloc success
*Mar 19 02:05:36.078:  cc_get_feature_vsa count is 1
*Mar 19 02:05:36.078: :FEATURE_VSA attributes are: feature_name:0,feature_time:8
33500504,feature_id:34
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, P
   Called Number=00283376014(TON=National, NPI=ISDN))
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/cc_process_call_setup_ind:
   Event=0x317E8F28
*Mar 19 02:05:36.078: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 00283376014
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/ccCallSetContext:
   Context=0x309CD8EC
   >>>>CCAPI handed cid 34 with tag 25 to app "_ManagedAppProcess_Default"
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/ccCallProceeding:
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=10, Params=0x309CED54, Progress Indication=NULL(0)
*Mar 19 02:05:36.078: //34/7ABC0ED929EC/CCAPI/ccCheckClipClir:
ation=Allowed)
tation=Allowed)
   Destination Pattern=0.T, Called Number=00283376014, Digit Strip=TRUE
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentatio
n=Allowed),
   Redirect Number=, Display Info=
   Account Number=10.240.16.80, Final Destination Flag=TRUE,
   Guid=7ABC0ED9-262E-001F-29EC-B54ABBD83117, Outgoing Dial-peer=10
*Mar 19 02:05:36.082: //34/7ABC0ED929EC/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=00283376014
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 02:05:36.082: //34/7ABC0ED929EC/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B18EC1C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screeni
ng=Not Screened, Presentation=Allowed),
   Called Number=00283376014(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10
, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
*Mar 19 02:05:36.082: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 02:05:36.082: :cc_get_feature_vsa malloc success
*Mar 19 02:05:36.082:  cc_get_feature_vsa count is 2
*Mar 19 02:05:36.082: :FEATURE_VSA attributes are: feature_name:0,feature_time:8
33500280,feature_id:35
*Mar 19 02:05:36.082: //35/7ABC0ED929EC/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Mar 19 02:05:36.082: //35/7ABC0ED929EC/CCAPI/ccCallSetContext:
   Context=0x309CED04
*Mar 19 02:05:36.082: //34/7ABC0ED929EC/CCAPI/ccSaveDialpeerTag:
*Mar 19 02:05:36.082: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0088 call
ID = 0x8009 switch = primary-net5 interface = User
*Mar 19 02:05:36.082: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0088
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Called Party Number i = 0xA1, '0283376014'
                Plan:ISDN, Type:National
*Mar 19 02:05:37.094: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x
8088
*Mar 19 02:05:37.094: //35/7ABC0ED929EC/CCAPI/cc_api_call_proceeding:
   Interface=0x2B18EC1C, Progress Indication=NULL(0)
*Mar 19 02:05:37.102: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0
x8088
        Cause i = 0x849F - Normal, unspecified
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 19 02:05:37.102: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect
; Postpone sending RELEASE for callid 0x8009
*Mar 19 02:05:37.102: //35/7ABC0ED929EC/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=31, Progress Indication=INBAND(8), Interface=0x2B18EC1C
   Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
*Mar 19 02:05:37.102: //34/7ABC0ED929EC/CCAPI/ccCallDiscProgInd:
   Call Entry(Responsed=TRUE, Disconnect Cause=31)
*Mar 19 02:05:37.102: //34/7ABC0ED929EC/CCAPI/ccConferenceCreate:
   (confID=0x2A25A5E4, callID1=0x22, gcid=0-0-0-0, tag=0x0)
*Mar 19 02:05:37.102: //35/7ABC0ED929EC/CCAPI/ccConferenceCreate:
   (confID=0x2A25A5E4, callID2=0x23, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x2A25A5E4, Call Id1=34, Call Id2=35, Tag=0x0
*Mar 19 02:05:37.102: //34/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 19 02:05:37.102: cc_api_get_xcode_stream : 4702
*Mar 19 02:05:37.102: //34/7ABC0ED929EC/CCAPI/cc_api_bridge_done:
   Conference Id=0xF, Source Interface=0x31565BAC, Source Call Id=34,
   Destination Call Id=35, Disposition=0x0, Tag=0x0
*Mar 19 02:05:37.102: //35/7ABC0ED929EC/CCAPI/cc_api_bridge_done:
   Conference Id=0xF, Source Interface=0x2B18EC1C, Source Call Id=35,
   Destination Call Id=34, Disposition=0x0, Tag=0xFFFFFFFF
*Mar 19 02:05:37.102: //34/7ABC0ED929EC/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xF, Destination Call Id=35)
   Call Entry(Conference Id=0xF, Destination Call Id=34)
*Mar 19 02:05:37.102: //35/7ABC0ED929EC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31565BAC, Destination Call Id=34, Source Call Id=35,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Mar 19 02:05:37.102: //34/7ABC0ED929EC/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=34
*Mar 19 02:05:37.102: //35/7ABC0ED929EC/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2B18EC1C, Destination Call Id=35, Source Call Id=34,
   Caps(Codec=0x2, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9190)
*Mar 19 02:05:37.106: //35/7ABC0ED929EC/CCAPI/cc_api_caps_ack:
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xF, Call Id1=34, Call Id2=35
*Mar 19 02:05:37.106: //35/7ABC0ED929EC/CCAPI/cc_api_voice_mode_event:
   Call Id=35
   Call Entry(Context=0x309CED04)
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x31565BAC, Call Id=34
   Call Entry(Responsed=TRUE, Cause Value=31, Retry Count=0)
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/ccConferenceDestroy:
   Conference Id=0xF, Tag=0x0
*Mar 19 02:05:37.106: //34/7ABC0ED929EC/CCAPI/cc_api_bridge_drop_done:
*Mar 19 02:05:37.106: //35/7ABC0ED929EC/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=34, Disposition=0x0, Tag=0x0
*Mar 19 02:05:37.110: //34/7ABC0ED929EC/CCAPI/cc_generic_bridge_done:
*Mar 19 02:05:37.110: //35/7ABC0ED929EC/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=31)
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
*Mar 19 02:05:37.110: //35/7ABC0ED929EC/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar 19 02:05:37.110: //34/7ABC0ED929EC/CCAPI/ccCallDisconnect:
ause=31)
*Mar 19 02:05:37.110: //34/7ABC0ED929EC/CCAPI/cc_api_get_transfer_info:
*Mar 19 02:05:37.118: //34/7ABC0ED929EC/CCAPI/cc_api_get_transfer_info:
*Mar 19 02:05:37.122: //34/7ABC0ED929EC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31565BAC, Tag=0x0, Call Id=34,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Mar 19 02:05:37.122: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 02:05:37.122: :cc_free_feature_vsa freeing 31AE3550
*Mar 19 02:05:37.122:  vsacount in free is 1
*Mar 19 02:05:37.130: //35/7ABC0ED929EC/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=31
   Call Entry(Disconnect Cause=31)
*Mar 19 02:05:37.130: //35/7ABC0ED929EC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B18EC1C, Tag=0x0, Call Id=35,
*Mar 19 02:05:37.130: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 02:05:37.130: :cc_free_feature_vsa freeing 31AE3470
*Mar 19 02:05:37.130:  vsacount in free is 0
*Mar 19 02:05:37.134: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00
88
*Mar 19 02:05:37.146: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x8088
I saw this exact thing happen once with a Fax Server.  I used Wireshark and it looked like the fax server was sending malformed H.323 packets.  Switching to SIP resolved the issue.  I believe they eventually gave us an updated version of the Fax Server software which had resolved the bug.
Thanks Brian
Worked it out with some help with some contacts
The issue was the E1 Interface needed an ISDN map for H323. I added this and offwe went with a smile
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn map address .* plan unknown type unknown
no cdp enable
563
