02-28-2014 03:05 AM - edited 03-18-2019 11:20 AM
Hi is there on
on a 2911 a mib oid to supervise per E1/T1 links the number of active calls on it?
i can't find it
thanks
Solved! Go to Solution.
02-28-2014 03:40 AM
Hi Alain.
This mib will give you the total calls value as returned by the command show voice call status
SNMPv2-SMI::enterprises.9.9.63.1.3.3
Carlo
Please rate all helpful posts
"The more you help the more you learn"
02-28-2014 03:40 AM
Hi Alain.
Carlo
02-28-2014 08:02 AM
thanks
i found another one after all
1.3.6.1.4.1.9.9.63.1.3.3.0 just found that the last 0 is important!
unfortunately it seems nothing is planned to be able to split by E1 link
there's just a common valmue and not by bearer
02-28-2014 10:47 AM
Yes Alain,
My mib was incomplete.
Sorry :)
For one of my customer I found a mib countig calls matching a particular dialpeer.
If you think that could be usefull for you, I can check on customer monitoring tool and send you here.
Let me know
Carlo
03-03-2014 12:15 AM
yes that would be great as each of my e1 link have a specific dial peer
thanks for helping
03-03-2014 05:57 AM
I found this table cvPeerCfgEntry
.1.3.6.1.4.1.9.9.63.1.3.8.4
that gives the list of in and out per dial peer it looks the best thing we can find
is it this one you were talking?
thanks
Alain
