2911 gtw knowing number of calls in snmp
Hi is there on
on a 2911 a mib oid to supervise per E1/T1 links   the number of active calls on it?
i can't find it
thanks
1 ACCEPTED SOLUTION
Hi Alain.
This mib will give you the total calls value as returned by the command show voice call status
SNMPv2-SMI::enterprises.9.9.63.1.3.3
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Alain.
Carlo
thanks
i found another one after all
1.3.6.1.4.1.9.9.63.1.3.3.0 just found that the last 0 is important!
unfortunately it seems nothing is planned to be able to split by E1 link
there's just a common valmue and not by bearer
Re: 2911 gtw knowing number of calls in snmp
Yes Alain,
My mib was incomplete.
Sorry :)
For one of my customer I found a mib countig calls matching a particular dialpeer.
If you think that could be usefull for you, I can check on customer monitoring tool and send you here.
Let me know
Carlo
yes that would be great as each of my e1 link have a specific dial peer
thanks for helping
I found this table cvPeerCfgEntry
.1.3.6.1.4.1.9.9.63.1.3.8.4
that gives the list of in and out per dial peer it looks the best thing we can find
is it this one you were talking?
thanks
Alain
222
