2911 router cme
how to configure e1 lines for 2911 router and incoming and out going dial-peer
2911 router cme
There are plenty examples on how to configure E1s on CSC, you just need to do some search, for DPs, if you search dial peer configuration on CCO, you'll find all the related documentation.
If you're also going to configure CME, there's the CME configuration guide on CCO which contains all you need.
Have you reviewed any of those???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
2911 router cme
Good luck!
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
dial-peer voice 1 pots
translation-profile incoming frm-pstn
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 9 pots
translation-profile outgoing to-pstn
destination-pattern 9T
port 0/0/0:15
Thank You
Sarawut Sampaothong
124
