2912 ip phone problems
Dear.
I have a problem with the IP phone model 2970, which at times does not receive energy and block, and to solve this problem momentarily preciona 3 times the number 3 and up again, my question is why this problem occurs, and how I can fix it?
thank you very much
              Juan Ibañez
  • IP Telephony
1 REPLY
Juan,
There is no 2912 or 2970 series of IP Phone from Cisco. However, if your IP Phone is facing any issue of frequent power cut, please ensure you have the right quality ethenet cable or simply use the power adaptor for that phone.
Not sure if I understood the issue right but reading the description, above is my opinion about your issue.
GP
Pls rate the post if it helps.
178
