09-12-2014 04:56 AM - edited 03-17-2019 12:08 AM
I have 2921 cisco router with cme v8.1 and around 40 ip phones registered .
I need to upgrade cme to version 10 do I will face any problem with license after upgrade ios ?
BR
Mahmoud
Solved! Go to Solution.
09-14-2014 06:17 AM
can u share output of show license detail cme-srst and show version ?
regds,
aman
09-14-2014 10:54 PM
#sh license detail
Index: 1 Feature: CollabProSuitek9 Version: 1.0
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
Store Index: 4
Store Name: Built-In License Storage
Index: 2 Feature: NtwkEssSuitek9 Version: 1.0
Store Index: 3
Index: 3 Feature: SNASw Version: 1.0
Store Index: 6
Index: 4 Feature: cme-srst Version: 1.0
License State: Active, In Use
Evaluation period left: 3 weeks 3 days
Period used: 5 weeks 0 day
Transition date: Oct 10 2015 01:15:56
License Count: 58/0 (In-use/Violation)
License Priority: Low
Store Index: 7
Index: 5 Feature: datak9 Version: 1.0
Store Index: 2
Index: 6 Feature: ios-ips-update Version: 1.0
Store Index: 5
Index: 7 Feature: ipbasek9 Version: 1.0
License Type: Permanent
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 8 Feature: securityk9 Version: 1.0
Store Index: 0
Index: 9 Feature: uck9 Version: 1.0
Store Index: 1
Index: 10 Feature: uck9 Version: 1.0
License State: Inactive
Store Index: 1
09-14-2014 11:45 PM
Issue the command sh license EULA and capture output.
Now issue the command license accept end user agreement and again check by using command show license EULA.
regds,
aman
09-15-2014 12:45 AM
same output before and after
r(config)#license accept end user agreement
#show license euLA
Feature name EULA Accepted
ipbasek9 n/a
securityk9 no
uck9 n/a
datak9 no
NtwkEssSuitek9 no
CollabProSuitek9 no
ios-ips-update no
SNASw no
hseck9 n/a
cme-srst yes
mgmt-plug-and-play n/a
mgmt-lifecycle n/a
mgmt-assurance n/a
mgmt-onplus n/a
mgmt-compliance n/a
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO PRODUCT FEATURE OR USING SUCH
PRODUCT FEATURE CONSTITUTES YOUR FULL ACCEPTANCE OF THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
Use of this product feature requires an additional license from Cisco,
together with an additional payment. You may use this product feature
on an evaluation basis, without payment to Cisco, for 60 days. Your use
of the product, including during the 60 day evaluation period, is
subject to the Cisco end user license agreement
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
If you use the product feature beyond the 60 day evaluation period, you
must submit the appropriate payment to Cisco for the license. After the
60 day evaluation period, your use of the product feature will be
governed solely by the Cisco end user license agreement (link above),
together with any supplements relating to such product feature. The
above applies even if the evaluation license is not automatically
terminated and you do not receive any notice of the expiration of the
evaluation period. It is your responsibility to determine when the
evaluation period is complete and you are required to make payment to
Cisco for your use of the product feature beyond the evaluation period.
Your acceptance of this agreement for the software features on one
product shall be deemed your acceptance with respect to all such
software on all Cisco products you purchase which includes the same
software. (The foregoing notwithstanding, you must purchase a license
for each software feature you use past the 60 days evaluation period,
so that if you enable a software feature on 1000 devices, you must
purchase 1000 licenses for use past the 60 day evaluation period.)
Activation of the software command line interface will be evidence of
your acceptance of this agreement.
09-15-2014 02:00 AM
Your UC license seems to be diabled.
Can u try license feature uck9 command and then, license boot module technology-package under config mode?
regds,
aman
09-15-2014 02:58 AM
no license feature uck9 command
(config)#license feature ?
mgmt-assurance mgmt-assurance license
mgmt-compliance mgmt-compliance license
mgmt-lifecycle mgmt-lifecycle license
mgmt-onplus mgmt-onplus license
mgmt-plug-and-play mgmt-plug-and-play license
applied command
(config)#license boot module c2900 technology-package uck9
but no change
09-15-2014 03:02 AM
DId u Accept as "YES" and then, reload the router?
regds,
aman
09-15-2014 03:51 AM
no confirmation appeared to me
09-15-2014 03:57 AM
U are missing something
can u follow the steps ?
a. license feature uck9
b.license boot module c2900 technology-package uck9
c.license accept end user agreement
regds,
aman
09-15-2014 04:36 AM
license feature uck9 command is not supported
but other commands make no change
09-15-2014 04:39 AM
Do u have uc license backup available ?
u can check in show flash: and install it again using
license install flash:uck9_license.lic
regds,
aman
09-15-2014 10:14 PM
no I don't have but I can issue license save command ,is that helps?
09-15-2014 11:45 PM
Hi ,
Can u share output of show flash:?
regds,
aman
09-16-2014 12:03 AM
09-16-2014 12:11 AM
Hi ,
I can see u do not have uc license in flash.
can u initiate the mail to licensing@cisco.com for providing the UC license?
you need to share the show license udi from router along with contract number.
regds,
aman
