11-02-2011 07:41 PM - edited 03-16-2019 07:50 AM
Hello guys.
I have bought a second hand 2921 router for my personal lab. The router came with only ipbase license. That means I cannot use cme and also cannot configure the router with any gateway functionality.
My question is. If I want to enable cme and voice-gateway functionality. H323 and mgcp.
What all license I need to buy ?
Need advice.
11-04-2011 05:23 PM
any one ??????
11-04-2011 05:57 PM
you need the unified communications license.
11-04-2011 08:29 PM
Hello!
The license is the UCK9 to be exactly.
11-05-2011 08:18 AM
To enable Unified Communication support you need to buy these licenses:
SL-29-UC-K9 --> UC License
FL-CME --> CME License (this is free)
FL-CME-SRST-5 --> 5 Seat License for CME
You probably need to buy PVDM2 or PVDM3 DSPs to support voice calls as they do not come bundled with IPBase
Thank you.
11-05-2011 08:50 AM
the pvdm's are not required if it is a VoIP only lab. You would need the pvdm's if you plan on integrating your lab with the Pstn.
11-07-2011 02:08 AM
Or you can active UCK9 Evaluation License in 60 days. This time should enough to take your test lab.
