Community Member
2MFT-E1 - ISDN
Hi.
It's possible to configure 2 signaling ISDN in same 2MFT-E1?
My customer have a link ISDN-NET5 and another ISDN-QSIG.
In global configuring mode, I enter the command isdn-net5. If I enter the isdn-config command, the isdn-net5 will be deleted?
1 REPLY
Community Member
Re: 2MFT-E1 - ISDN
you can configure them at per serial interface level also.
int ser0/0/0:15
isdn switch-type pri-net5
int ser0/0/1:15
isdn switch-type isdn-qsig
cheers
Shahid
101
