Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
2nd call line display
If you have 2 lines on a phone and one is active in call - a call to the 2nd line can only flash/beep/ring.....is there a way to have it show up on the screen?
It does this for a 2nd call to the line that is active but not another line.
Manish
1 REPLY
Hall of Fame Super Red
Re: 2nd call line display
Hi Manish,
Try changing the System setting Auto-Line Select. With this Enabled the Display Focus (and Softkeys) always switch to the new incoming call.
Also available on an individual phone via this setting;
Device>Phone>Phone Configuration>Product Specific Configuration>Auto Line Select>Enabled
Hope this helps!
Rob
115
