2nd line function on a 7942 phone
I want to have the ability to either call fwd all my second line (currently when I try I get the "that key is not active here" msg)  or make it so my 2nd line is the default line used for outbound calls.  Is this possible?  How?
CCM 8.5
Thank you
No way to set CFA from the phone for any other line if not the primary line. There are plenty of threads on that, please search CSC for answers.
http://www.myvoipsource.org/open-source-tools/ip-phone-callforwarder/
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi.
A workaround is to create an end user , associate his/her ip phone to that user , define this user as a cucm end user.
The user, than, can login into https:///ccmuser and ,from this page, manage call forward of the second line only.
Carlo
Please rate all helpful posts "The more you help the more you learn"
621
