3 and 4 digit mix
Our HQ site only have 3 digits ext on CUCM. We are brining on a branch office setup as SRST, the branch will have 4 digits ext. The initial issue we are having is some users at the HQ ext. are 421,422,423. At the branch we are going ot use 4200-4300 for exts. So if you are trying to call 422 when an ext in the branch is 4223 your call to 422 never goes through. Is there a way we can have these calls go through
Hall of Fame Super Silver
Re: 3 and 4 digit mix
You need to ensure there are no overlaps if you desire seamless dial plan. I would recommand changing all DNs to 4 digits or adjusting the HQ or remote site DNs not to overlap.
Chris
calls should go thru if you have configured CSS and partitions the right way. try dialing and pressing # or wait 15 seconds for the call to go. those are the only 2 things you can do/wait when calling a 3 digit DN
try changing the T_302 timer to something less than 15 seconds but you will need to wait.
only way to avoid is to use other initial digit or to use 4 digits everywhere (no overlapping)
java
if this helps, please rate
java
www.cisco.com/go/pdi
96
