3 Servers upgrade from 5.X to 7.X
Please assist me to upgrade the CUCM from 5.x to 7.x in which I have 2 Subscriber and 1 Publisher.
Please let me know the process which server should I upgrade 1st and followed by others.
Rgds.....
NS.
Re: 3 Servers upgrade from 5.X to 7.X
Install the upgrade patch on PUB, then SUB1 and finally SUB2.
Once it's installed then you switch versions on PUB, wait until it fully comes up and switch SUB1, wait until it fully comes up and the switch SUB2
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi JAVA,
Thank you for the steps, however, is there any documention of how to upgrade the servers in a Cluster.
Rgds.....Navinder
Brian already posted such link
java
java
This document provides an excellent overview of the process:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
Good luck.
Brian
Thank you for the link, however, is there any documention of how to upgrade the servers in a Cluster.
Rgds.....Navinder
There's a link within the upgrade doc to the release notes. Follow the release notes for more info.
Hope that helps.
Brian
185
