08-07-2009 07:32 PM - edited 03-18-2019 10:30 AM
I purchased 3500XL switch for my Voice Lab Call Manager 4.1(3)sr8.
It doesn't support POE so I had to purchase external power kit for my (2)7960 IP Phones. Configuration below, I applied to my 3500XL switch, but I couldn't get it to work with IP Phones. The Phones wouldn't get registered to Call Manager, and wouldn't receive IP Address via DHCP. I even configured the phone with static IP Address, but couldn't ping the phone from the Publisher or Subscriber.
To minimize the complexity, I put both servers and IP Phones on the same Vlan.
Ports 1 and 2 are assigned to Pub/Sub, and Ports 14 and 15 assigned to IP Phones.
Config for the Servers:
interface fa0/1
switchport access vlan 10
interface fa0/2
interface fa0/14
switchport voice vlan 10
switchport mode trunk
switchport priority extend trust
interface fa0/15
Static configuration for Phone:
IP address---- 172.16.1.10
DG--- 172.16.1.1
TFTP--- 172.16.1.2----Publisher
DHCP Server---Disabled
Couldn't ping the phone from the publisher.
Any feedback will be appreciated.
08-09-2009 12:58 AM
Abbas,
Did you add VLAN 10 to the VLAN database?
switch#vlan database
switch(vlan)# vlan 10
switch(vlan)# exit
HTH,
Mark
08-09-2009 06:13 AM
Hi All,
If the voice vlan is 10, please configure the ports connecting with IP phone with the following
interface FastEthernet0/12
description connect IP phone
spanning-tree portfast
It works fine for me.
Michael.
08-09-2009 10:57 PM
Yes, I did add the VLAN 10 in the database.
The only command I am missing is "switchport trunk encapsulation dot1q", but that should not stop the Layer 2 connectivity though. I had router on stick configuration on 2600XM router connected to 3500XL switch, and I defined the DHCP pool in a router, but the IP Phone wasn't able to receive the IP address from the pool. I then disabled DHCP Server on the phone, and statically assigned the IP Address below, but I couldn't ping the Publisher/Subscriber from the IP Phone. In a lab, I installed the CCM 4.1(3) sr8, but I don't if I have to enable any services in "Service Activation Menu" May be this is the problem, I guess.
08-09-2009 11:48 PM
If we don't define dot1q, the switch will use cisco ISL as default encapsulation.
Did you add the dot1q command for testing?
The Publisher should connect to a port that mode should be configured access mode and don't change it to trunk mode.
Let the Publisher work as DHCP server, it should be work.
Michael.
