3750 as DHCP
mahbubul karim
Hello
after a 2 year break I finially managed to get hold of some kit and decided to go for the last 3 exams of my CCNP Voice. Just started from scract. I have a 3750 which I am configuring as DHCP source. The initial config is below, after doing the initial configuration, I connected a G5 server which got an IP address, virtual servers installed on the G5 got IP addresses too. However I am stuggling to get phone booting up as the phone was factory resetted before.
This is how the devices are conencted to 3750 swicth.
Gi1/0/1 - HP G5 server running CUCM PUB and SUB
Gi1/0/2 - Laptop
Gi1/0/3 - Cisco IP Phone 7961
Phone is stuck at factory reset, so I can't manually configure TFTP in the phone.
Question is - How do I get the phone to talk to CUCM to get the initial config file ?
Any help would be appriciated.
3750 Config
DHCP_SW#sh run
Building configuration...
Current configuration : 6272 bytes
version 12.2
no service pad
hostname DHCP_SW
boot-start-marker
boot-end-marker
enable secret 5 $1$iJMc$zgLJ1Z3MVI.sK2gEcaVE.1
no aaa new-model
switch 1 provision ws-c3750e-48pd
system mtu routing 1500
ip subnet-zero
ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 10.125.100.1
ip dhcp excluded-address 10.125.200.1
ip dhcp excluded-address 10.125.100.3
ip dhcp excluded-address 10.125.100.7
ip dhcp pool vlan100
   network 10.125.100.0 255.255.255.0
   default-router 10.125.100.1
ip dhcp pool vlan200
   network 10.125.200.0 255.255.255.0
   default-router 10.125.200.1
ip dhcp pool Voice_DHCP
   option 150 ip 10.125.100.0
ip dhcp pool Voice_DHCp
crypto pki trustpoint TP-self-signed-1890746624
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1890746624
revocation-check none
rsakeypair TP-self-signed-1890746624
crypto pki certificate chain TP-self-signed-1890746624
certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31383930 37343636 3234301E 170D3933 30333031 30303336
  33345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38393037
  34363632 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E8D1 F48AC7EA 5EC82A3F 5E93A8E0 6AF2F92E 51B8FB42 C8496B33 A7C217B3
  73DEBDF9 40A8D20E F2DCD1BC 429A0275 EB1E3EA1 286E63DA 88E04EA8 DF40858D
  6EF1ED56 67FD264E 3DDFFB62 A89A2367 21D532AA 8DCD6294 FCB1E2BC C8CEE3A3
  C5819E43 F9E75EFC 713E42C8 38349498 036885B3 C6F5715C B277C301 DAE875F4
  ABBB0203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603
  551D1104 0C300A82 08444843 505F5357 2E301F06 03551D23 04183016 80143F98
  B9015E5C 49F193B6 7F589F95 079631C7 2CBD301D 0603551D 0E041604 143F98B9
  015E5C49 F193B67F 589F9507 9631C72C BD300D06 092A8648 86F70D01 01040500
  03818100 6765D542 A7E40331 EF511347 EF6A129E EE791BC4 5E5C0865 DFA3D5AD
  9394795A A13BF857 972B2551 6F1CC63C C4FAA0ED 91948F89 D354C24F 27F73584
  833DF08D 50B99CB1 04E4A7E2 1D9C9A63 E97CF503 E8D5AD94 9AD76914 F163A690
  8481DFCF CD55BD37 9CF95312 E2267AD9 09E0A10E 8813DFBC 691CC0C2 03414A00 BD0EA9BD
  quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet1/0/1
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 200
speed 100
duplex full
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
ip address dhcp
interface Vlan10
ip address 10.0.0.1 255.255.255.0
interface Vlan100
description Voice_DHCP
ip address 10.125.100.1 255.255.255.0
ip helper-address 10.125.100.0
interface Vlan200
description Data_DHCP
ip address 10.125.200.1 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
Chris Deren
Your Voice DHCP scope has option 150, but does not have a network specified.
Your voice interface has helper defines, what is it? Do you want to use external DHCP for that?
Alos, all of your ports are not configured for voice vlan, you need to add:
interface GigabitEthernetx/o/x
switchport voice vlan 100
Chris
Hi Chris
Thanks for your reply. I have changed the port config, still no luck. The switch is acting as DHCP, no external DHCP.
Sh run config is below -
DHCP_SW#sh run
Current configuration : 9586 bytes
version 12.2
no service pad
hostname DHCP_SW
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip routing
   option 150 ip 10.125.100.7
mls qos map policed-dscp  24 26 46 to 0
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
  quit
class-map match-all AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-all AutoQoS-VoIP-Control-Trust
match ip dscp cs3  af31
policy-map AutoQoS-Police-CiscoPhone
class AutoQoS-VoIP-RTP-Trust
  set dscp ef
  police 320000 8000 exceed-action policed-dscp-transmit
class AutoQoS-VoIP-Control-Trust
  set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
no ip address
no ip route-cache
no ip mroute-cache
spanning-tree portfast
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AutoQoS-Police-CiscoPhone
speed 100
duplex full
interface Vlan1
ip address dhcp
interface Vlan10
interface Vlan100
interface Vlan200
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
I think I know why ...
You said your PUB and SUB are in G 1/0/1 right?
If I remembered correctly, should the PUB/SUB be in the Voice VLAN (VLAN 100) instead of VLAN 200?  Shoud the PUB/SUB have the same subnet as the phones?
If this is so, then your Gi1/0/1 should be "switchport access vlan 100".
Post the output to the command "sh ip dhcp bind".
