3800 ISR integration with Bogen T100 paging
Looking for any info on integration between a 3800 ISR and a bogen overhead paging amplifer/system.  I would assume the standard vwic2-fxs card would be sufficient, but I have read that there is an extended loop (vic2-2fxs-e/did)  version with higher ringing current  of this and wonder if it would be beneficial to get this card.
any help is appreciated.
thanks
Hall of Fame Super Silver
I am not familiar with T100, is this a paging adapter or paging amplifier, zone controller?
With paging adapter, i.e. TAMB2 you  can use either FXO (trunk) or FXS (station) connection and both work very well.
Chris
Yes, use Bogen TAMB between FXS and T100.  FXO can work too, but then you need to add -24V power supply for TAMB.  With FXS power supply is not needed.
-- please remember to rate and mark answered helpful posts --
Thanks, all, for the responses.  I am told now that i am connecting to a Bogen C60B amplifier.  Im assuming a fxs to a Bogen TAMB is still the way to go?
just an FYI, I got this working with FX0--->Bogen UTI1 Adapter-----> Bogen C60B
Thanks for  all the suggestions
485
