3825 ISR maximum IP Phones
femi.agboade
I have a callmanager setup with the following infrastructure:
ISR 3825
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Number of IP Phones: 168
CallManager Express 7.1
I know that Cisco's documentation states that the mximum number of phones that can be supported by the 3825 is 168. I would just like to know if there is a way on increasing this number as I have need for more phones on the network.
Femi
2 Accepted Solutions
paolo bevilacqua
The limit is actually 175, plus some extra allowance.
There is no way to increase this number.
this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.htm
says
Maximum Total IP Phones
Cisco 3825 = 175
Note: Total number of connected IP phones cannot exceed Maximum Total listed including  SCCP and SIP phones on the same router.
6 Replies 6
paolo bevilacqua
this link
says
Cisco 3825 = 175
Actually, the 'Total limit' is not enforced.
Hello Paolo,
Does this imply I can keep adding phones without the limit if 175 being enforced? You seen it happen before?
Femi
Type in "max-ephones ?" and see what it lets you do.
Chris
femi.agboade wrote:
Hello Paolo,
Femi
No. I was referring 'total number' of SIP and SCCP.
