3825 MGCP Transcoder is down
I am after advice regarding using a 3825 as a transcoder wih CCM 4.1 and MGCP
The 3825 is running on IOS 12.4(5a) with MGCP
The transcoder is configured on CCM as "Cisco IOS Media Termination Point"
Description and device name are the 3825 chassis MAC address.
The registration is unknown and the IP address field is blank
On the gateway the DSP shows as admin down
The gateway is up and is taking calls via the ISDN PRI no problem.
On the gateway Sh DSP Farm all results in
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Any advice on where I should start with this ?
Re: 3825 MGCP Transcoder is down
1st - Making sure shutdown is not in the dspfarm profile config.
You should see the IP address update even if there is a registration problem.
We have the following entry
isdn switch-type primary-net5
voice-card 0
no dspfarm
no local-bypass
Sorry but I was told previously that it was not necesary to do any config in the gateway as CCM would download it via the MGCP config, is this not right ?
Super Bronze
The router can download config from CallManager for things related to MGCP and gateway-type call processing.
Unfortunately you still need to manually configure the box for transcoding/conferencing and such.
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541bf3.html
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
244
