3845 Transcode not associated
Hello all, I am trying to setup our 3845 to do some transcoding. Hhere is my config:
voice-card 0
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0.20
sccp ccm 192.168.100.1 identifier 1 version 4.1
sccp ccm group 1
bind interface GigabitEthernet0/0.20
associate ccm 1 priority 1
associate profile 1 register trans1233
keepalive retries 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 4
sdspfarm tag 2 trans1233
conference hardware
ip source-address 192.168.100.1 port 2000
max-conferences 12 gain -6
transfer-system full-consult
My problem:
#show dsp profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE IN PROGRESS
Application : SCCP Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 6
Number of Resource Available : 6
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g729br8, Maximum Packetization Period : 60
I am concerned about the "active in progress" for the association. Am I missing something?
Re: 3845 Transcode not associated
You should have sccp enabled.
sccp
If you still have this problem try removig the version of CM in the config. With some IOSs you have to do this...
sccp
BR,
Stoyan
oops, I did have he sccp in there, I just pasted too soon. So it was giving me the error even with sccp enabled in global.
I followed your suggestion and changed my config to:
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
and still get:
show dsp profile 1
Codec Configuration
This router has only been a voice gateway in the past and has never run anythig under CME, perhaps CME is missing something here? hmmm very confused here.
Running the following:
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Hall of Fame Super Silver
Configure this command:
as
sccp ccm 192.168.100.1 identifier 1  version 7.0 (or whatever the latest available version on this IOS is)
HTH,
Chris
It look like gatewy try to register on CM but cannot find this transcoder configuration (trans1233). Create new transcoder or check correct spelling on CM(CM and Gateway names have to be identical).
1390
