3905 phone won't register with srst gateway
Hi Fellows
i got an issue, if you could help me would be great. I have a bunch of 3905 in a remote office and when loses connectivity with the call manager won't register with the local gateway, i check the phone and in the telephony information shows me active server:<ip_publisher> and stand by server: <ip_subscriber> and does not have the option to put a third srst server.
I reviewed the pre requisites in cisco's web site and seems all in order
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs88spc.html
Version of the firmware phone : 9.2.1.0
Version of SRST : 8.8
Version of GW IoS : 15.2(1)T
Version of CM: 8.5.1 SU2
Thanks in advance
Best Regards
1 ACCEPTED SOLUTION
Silver
Re: 3905 phone won't register with srst gateway
Could you please post your SRSTSconfiguration? Since you need SIP SRST in order to re-register these phones to the GW, please check these links:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_41.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/feature/guide/srst71ft.html
HTH,
--espereir
Silver
HTH,
--espereir
Thanks you very much espereir, your post clarify me all, i take a look to the documentation that you provide me and i resolve the issue.
Thanks again
Hi Gramirez
I have the same problem. Could you put the configuration that solved the issue?
TIA
Cristian.
Hi!!
I have the same issue, Could you send me the gateway configuration please?
Regards!
Fellows,
The solution was to put configurations related to sip, these are the lines that i added
********* Enable SIP srst register **************
voice register global
system message XXX
max-dn 20
max-pool 20
********** Create the endpoints that are going to register with the gateway ************
voice register pool  1
id mac XXXX.XXXX.XXXX
number 1 711
codec g711alaw
********* SRST related **********
application
global
  service alternate Default
sip-ua
Hi Gramirez23,
Hi Gramirez23,
Currently am facing the same issue.. could you please put the router configuration here so that i can compare with mine..
mine is like this...
Building configuration...
Current configuration : 2798 bytes
! Last configuration change at 05:47:48 UTC Wed Sep 21 2016 by pyramid
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
enable password pyramid
no aaa new-model
ip dhcp pool sampath
network 192.168.0.0 255.255.255.0
default-router 192.168.0.199
option 150 ip 192.168.0.234
ip cef
no ipv6 cef
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
mode srst
timeouts interdigit 5
system message Fallback mode is active
max-dn 20
max-pool 10
authenticate presence
authenticate realm cisco.com
timezone 39
mwi unsolicited
voice register dn 1
number 100
allow watch
voice register pool 2
id mac 0008.2FB6.1628
number 1 dn 1
codec g711ulaw
application
global
license udi pid CISCO2901/K9 sn FGL1927239Q
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
hw-module pvdm 0/1
username pyramid password 0 pyramid
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 192.168.0.199 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sip-ua
gatekeeper
shutdown
credentials
ip source-address 192.168.0.199 port 2000
trustpoint CUCM
ephone-type 9971
device-id 9971
device-name CISCO IP Phone 9971
num-buttons 1
max-presentation 1
ephone-type 3905
device-id 3905
device-name CISCO CP3905
device-type SIP
num-buttons 1
max-presentation 1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
2722
