3925 Modem with E1 --- Call Termination Issue
Folks,
We have a 3925 running with ISDN E1 and PVDMII digital modem.
Communication Server uses Cisco Router(Modem) to dial out through E1 to remote modems.
Everything is working as per normal behavoir but the problem is an odd calls are taking too long to complete. An Average calls should not be more than 2 minutes however the last month's call logs suggest that there have been calls lasting for 20 minutes and one call lasting for 15 hours.
Which at the end has generated a massive bill. Just wondering if anyone have faced similar issues?
Basic config
modem-pool XXXX-MODEM-POOL
pool-range 0/387 0/422
called-number XXXXXXxx max-conn 30
modem country v12 e1-default
modem recovery threshold 20
modem recovery action disable
ip cef
controller E1 0/0/0
pri-group timeslots 1-31
description **** E1
controller E1 0/0/1
vlan 495
name Lan Connection
interface Serial0/0/0:15
description ***ISDN Control Channel***
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no peer default ip address
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice modem 64
isdn calling-number XXXXXXXX
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
interface GigabitEthernet0/1/0
switchport access vlan 495
no ip address
interface GigabitEthernet0/1/1
interface Vlan495
description *****Servers*****
ip address X.X.X.X 255.255.255.0
interface Group-Async1
description ***PVDM2-36 Digital Modems***
no ip address
encapsulation ppp
load-interval 30
dialer in-band
async dynamic address
async mode interactive
no keepalive
ppp callback accept
group-range 0/387 0/422
routing dynamic
201
