3925E Gateway Sizing Numbers with VXML
Are there any gateway sizing options document for Router 3925E?
We are trying to figure out the scalability numbers for 3925E if we use it as a router and a vxml browser.
The sizing table below only talks upto 3800 series.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/customer_voice_portal/srnd/7x/cvp_gtwy.html#wp1049701
Are the routers generally good enough for large deployments or CVP is preferred?
Any link/pointer would be really appreciated. Thanks.
Anupam
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Hall of Fame Super Gold
For such question use "IP telephony" forum.
Thanks Paolo. I have moved the discussion to IP Telephony.
Looking forward to people's views on the question.
Anupam
Thanks Chris! That was very helpful!
Looks like I was searching only the 3925E docs and not the CVP docs for all this while.
btw, the performance numbers are way up for 3925E than 3825!
Cheers
Anupam
1730
