3945 E1 Cable And Wirless disconnect issue
We have a 3945 with a Cable and Wireless E1 circuit on it in the UK. The CUCM version is 7.1.5
When we receive inbound calls and hang up the call from the ipphone, the call clears from the IPphone but the other end sees the call still active.
When we disconnect the call from the pstn side, it clears correctly on both ends.
Below is a debug isdn q931 from a call disconnected from the ipphone side :
GBWEYVG01#
*May 27 10:02:14.331: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0007
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x00C3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '6998'
*May 27 10:02:14.331: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8007 callID = 0x0061 switch = primary-net5 interface = User
*May 27 10:02:14.347: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8007
*May 27 10:02:14.347: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8007
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*May 27 10:02:16.315: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8007
*May 27 10:02:16.331: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0007
<<<<<<<<<This is the moment we press the call end button on the ipphone, the call is still connected on the pstn phone then>>>>>>>>>>>>>>>>>>
*May 27 10:02:20.907: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8007
        Cause i = 0x8090 - Normal call clearing
GBWEYVG01#
GBWEYVG01#
<<<<<<<<<This is the moment we press the call end button on the pstn phone>>>>>>>>>>>>>>>>>>
*May 27 10:02:41.775: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0007
        Cause i = 0x8290 - Normal call clearing
        Display i = '*AA*CLEARED#'
*May 27 10:02:41.775: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8007
How can we fix it so that the call disconnects normally?
Thanks in advance,
Jeroen
Everyone's tags (7)
Hall of Fame Super Gold
Re: 3945 E1 Cable And Wirless disconnect issue
There is nothing you can or should do beside complaing to telco.
The trace shows that router is disconnecting the call correctly, however CO doees not respond to that.
You can try if it makes any difference when the call is initiated as outbound rather than inbound, because some telco may still stick to the ancient concept that call can be disconnected only by the party that placed it.
Thanks, I have logged a ticket with the provider. Let's see what they come back with.
Rgds,
Jeroen
422
