3d Party IPhone SIP Client for UC500 Over VPN (Cisco Anyconnect)
Hi to everyone,
Does know anyone if there is a 3d party IPhone SIP Client compatible for UC500 that works over VPN?
Thank you!
  • IP Telephony
1 ACCEPTED SOLUTION
Re: 3d Party IPhone SIP Client for UC500 Over VPN (Cisco Anyconn
Hi.
Have you tried Xlite with a configuration similar to the following?
voice register dn 1
number 1000
voice register pool 1
id mac 0000.0000.1000
number 1 dn 1
username 1000 password cisco
codec g711ulaw
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
voice register dn 1
number 1000
number 1 dn 1
codec g711ulaw
Carlo
No, I haven't tryed anyone at time because I would like to be sure before give the solution. Is this client compatible with all models of IPhone? Have you ever tested and worked well?
I found this after your directions. http://www.counterpath.com/bria-iphone-edition.html I will try it and I will give back a feedback.
Thanks..!
Hi.
Just to give you an update.
For a more stable sip client for Iphone, choose zoiper. It's free and works ok.
With Xlite for iPhone I found many registration issues.
Carlo
Thank you very much for your reply. I will try it and I will send you back a feedback.
Do you know if Zoiper client works over VPN?
Thank you very much for all. After I contacted Zoiper company they told me that zoiper expected to work via my VPN client.
I have tried this configuration below but I can call only from iphone to another ext, and none from other ext can call me.
Any ideas?
voice register dn 1
number 1000
number 1 dn 1
codec g711ulaw
403
