Community Member
3rd party billing and Cisco CAR!
Hi all,
Our company currently use CCM 5.1 and we've used CAR for reporting. Now we want to try a 3rd party billing along with CAR tool.
But when configuring CCM to transfer the CDR files to the billing server, the CAR doesn't work as before. It show a message that the database is not available (from the day we configured the billing server)
Could someone suggest me a workaround for this case? (using both tools: CAR and a 3rd party tool)
hoanghiep
1 REPLY
Re: 3rd party billing and Cisco CAR!
Unfortuately I do not think this is possible - certainly not on CCM 4.2 which is all I have access to currently.
For CAR to work the CDR Format Enterprise Parameter needs to be set to CDRs will be inserted into database.
Some third party tools - such as Stonevoice BillyBlues - need this paramenter set to CDRs will be kept in flat files.
If your third party billing product uses the flat file option then the only way of using CAR as well would be to change the service parameter during a period when no calls would be made to allow the flat files to be inserted into the CAR database and then change it back again. Not really a sensible option!
Please note that this information is based upon version 4.2 - if 5 is different let me know!
239
