3rd party SIP device (gigaset) registration to CME fails
I am trying to get some 3rd party devices (gigaset DECT gateway 192.168.0.22) to register to a CME (192.168.0.79) box.
I have 3 x extensions configured on the Gigaset but I am getting SIP errors :-
000226: Sep 23 18:00:36.779: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000227: Sep 23 18:00:36.779: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000228: Sep 23 18:00:36.783: //49/E232B6C88021/SIP/Error/ccsip_spi_register_incoming_registration: Error during REGISTER for contact - 192.168.0.22 148
000229: Sep 23 18:00:36.783: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
The important bits of the config :-
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to sip
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 120 min 60
voice register global
mode cme
source-address 192.168.0.79 port 5060
max-dn 10
max-pool 10
load ATA SIPDefault.cnf
authenticate register
authenticate realm all
tftp-path flash:
create profile sync 0004623540902042
voice register dn  1
number 144
call-forward b2bua noan 100 timeout 20
allow watch
name 144
label 144
voice register dn  2
number 145
allow watch
name 145
label 145
voice register dn  3
number 148
allow watch
name 148
label 148
voice register pool  1
id mac 1111.1111.1111
type ATA
number 1 dn 1
dtmf-relay rtp-nte sip-notify
username 144 password 144
codec g711ulaw
voice register pool  2
id mac 2222.2222.2222
type ATA
number 1 dn 2
username 145 password 145
codec g711ulaw
voice register pool  3
id mac 3333.3333.3333
type ATA
number 1 dn 3
username 148 password 148
codec g711ulaw
Here's a debug ccsip error & ccsip messages :-
000225: Sep 23 18:00:36.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.0.79 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bK29b5ed11d73d42d113320c018fa2b75;rport
To: "148" <sip:148@192.168.0.79>
Call-ID: 1651868960@192_168_0_22
CSeq: 2 REGISTER
Contact: <sip:148@192.168.0.22:5060>
Authorization: Digest username="148", realm="all", qop=auth, algorithm=MD5, uri="sip:192.168.0.79", nonce="70DD181600048BD9", nc=00000001, cnonce="30b116ca9a5cecaa8077cd07fbb082c1", response="5374b412f7c295ac13bf5b6175869799"
Max-Forwards: 70
User-Agent: N720-DM-PRO/70.040.00.000.000
Expires: 60
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY
Content-Length: 0
000230: Sep 23 18:00:36.787: //49/E232B6C88021/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "148" <sip:148@192.168.0.79>;tag=2D7678-22D
Date: Mon, 23 Sep 2013 18:00:36 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 2 REGISTER
Content-Length: 0
000231: Sep 23 18:00:36.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REFER sip:148@192.168.0.22:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.79:5060;branch=z9hG4bKEAA9
To: <sip:148@192.168.0.22>
Call-ID: E238D0F0-23B011E3-8022ADAE-F94440D4@192.168.0.79
CSeq: 101 REFER
Max-Forwards: 70
Contact: <sip:192.168.0.79:5060>
User-Agent: Cisco-SIPGateway/IOS-12.x
Timestamp: 1379959236
Require: norefersub
Refer-To: cid:0297948
Content-ID: <0297948>
Content-Type: application/x-cisco-remotecc-request+xml
Referred-By: <sip:192.168.0.79>
Content-Length: 292
<?xml version="1.0" encoding="UTF-8"?><x-cisco-remotecc-request><statuslineupdatereq><action>notify_display</action><statustext>Max Phones Exceeded</statustext><displaytimeout>10</displaytimeout><linenumber>0</linenumber><priority>1</priority></statuslineupdatereq></x-cisco-remotecc-request>
000232: Sep 23 18:00:36.791: //49/E232B6C88021/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 2 REGISTER
Content-Length: 0
000233: Sep 23 18:00:36.811: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 420 Bad Extension
CSeq: 101 REFER
Unsupported: norefersub
Content-Length: 0
Would appreciate some assistance to get these DECT handsets to register if you can please.
Many thanks
Re: 3rd party SIP device (gigaset) registration to CME fails
Hi.
Can you try to remove "type ATA" from register pool 3?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
I removed the type ata, recreated profiles, reset the gigaset and still get the same errors :-
000102: Sep 23 19:33:51.807: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bK8a80a321ff44a7b29b99942e75800145;rport
To: "148" <148>
Call-ID: 3752067865@192_168_0_22
CSeq: 1 REGISTER
Contact: <148>
Max-Forwards: 70
Expires: 60
Content-Length: 0
000103: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000104: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000105: Sep 23 19:33:51.811: //25/E91E515B8012/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
000106: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
000107: Sep 23 19:33:51.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "148" <148>
Date: Mon, 23 Sep 2013 19:33:51 GMT
CSeq: 1 REGISTER
Content-Length: 0
000108: Sep 23 19:33:51.815: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: "148" <148>;tag=4A9BB0-267E
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="all",nonce="085726D5000775F8",algorithm=MD5,qop="auth"
Content-Length: 0
000109: Sep 23 19:33:51.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bKef933dc052dd58816154baef924488af;rport
To: "148" <148>
CSeq: 2 REGISTER
Contact: <148>
Authorization: Digest username="148", realm="all", qop=auth, algorithm=MD5, uri="sip:192.168.0.79", nonce="085726D5000775F8", nc=00000001, cnonce="d73b0e5cb55083abf1e6c04d57978c0d", response="f2b53d227a972ecc5048883a02e7d604"
Max-Forwards: 70
Expires: 60
Content-Length: 0
000110: Sep 23 19:33:51.843: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000111: Sep 23 19:33:51.843: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000112: Sep 23 19:33:51.851: //25/E91E515B8012/SIP/Error/ccsip_spi_register_incoming_registration: Error during REGISTER for contact - 192.168.0.22 148
000113: Sep 23 19:33:51.851: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
000114: Sep 23 19:33:51.851: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 2 REGISTER
Content-Length: 0
000115: Sep 23 19:33:51.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.79:5060;branch=z9hG4bK8717
To: <148>
Call-ID: E9246B84-23BD11E3-8013B5F2-6196802@192.168.0.79
CSeq: 101 REFER
Max-Forwards: 70
Contact: <192.168.0.79:5060>
Timestamp: 1379964831
Require: norefersub
Refer-To: cid:0488955
Content-ID: <0488955>
Referred-By: <192.168.0.79>
Content-Length: 292
notify_displayMax Phones Exceeded1001
000116: Sep 23 19:33:51.855: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 2 REGISTER
Content-Length: 0
000117: Sep 23 19:33:51.875: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <148>
CSeq: 101 REFER
Content-Length: 0
Best wishes,
Paul
Hi Paul.
Can you please also post a screenshot of gigaset configuration
Carlo
No problem Carlo.
Thanks for looking.
I'm uploading a sh run, and three screenshots from the Gigaset, one of the VoIP provider where we configure the CME details & a couple of pages for the actual handsets.
Hi Paul.
Thank you for attaching those info.
Have you tryed to upgrade to the latest IOS the CME?
Let me know
Carlo
932
