4.1(3) to 7.1 upgrade?
harris.h
Hi there I have ran the DMA upgrade tool for CUCM 7.1(3), this resulting tarball has been used to build the new 7.1(3a) server.
Problem I now have is phones are just sitting in 'opening 10.10.10.1' mode after doing their firmware upgrade.
I have not applied any license files yet, but was not expecting this behaviour, any ideas please.
This server has been built as a test.
Rich
Aaron Harrison
Have you verified the CCM service is running? go to serverip/ccmservice, log in and then go to Control Centre/Feature Services.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Jaime Valencia
http://ip_of_your_server
Once you get to CCMAdmin click on the top-right menu and go to serviceability.
Log in, check the status of the services.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
