4.2.3 Attendant Console / Pilot
Is it possible to configure attendant console without any pilot groups, and only use the DN. If so, what are the implications? Thanks
Re: 4.2.3 Attendant Console / Pilot
Yes. That is how I've always set it up. You can also use it without going online on the client.
I always thought that the pilot point was only for the Broadcast huntgroup feature...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsccmac.html
JoeL
just to add something if you have troubles we won't support your system unless configured using the guide. i know by testing that it works (kinda) but some stuff won't work or fail. so, you're free to configure it, but if you have trouble we won't support your system for any AC related matters until you configure it as explained in the AC config guide
java
if this helps, please rate
java
www.cisco.com/go/pdi
117
