4.2(3) Inter-cluster trunks not working!!!!
I just recently upgraded 2 call manager clusters from 3.3(5) to 4.2(3), and as soon as I did that, my intercluster trunks failed.
They are still not working, and I can't figure out why.
Can anybody provide information that might be useful.
These are non-gatekeeper controlled trunks. They worked great with CCM 3.3(5), but not with CCM 4.2(3).
Thank you,
Ben
1 REPLY
Re: 4.2(3) Inter-cluster trunks not working!!!!
Hi, i has the same problem. The calls from CCM 4.1 to CCM 6.0 works but the calls from CCM 6.0 to CCM 4.1 fast busy. It is solved adding in both trunk side the CCM Subcriber and Publisher IP.
I hope help you
Regars
Cristian
251
