Community Member
4.3/AD integration
I have a customer with the AD plugin installed. All my previous 4.x systems have been DCD based. The Publisher is in a workgroup and not the domain.
If I install a patch, do I have to re-install the plugin afterwards?
Would I need to remove it before running the patch?
Also what about moving from 4.3(1) to 4.3(2), same issues?
Any gotchas I should be aware of?
Many thanks.
1 ACCEPTED SOLUTION
Green
Re: 4.3/AD integration
For everytime you upgrade, YES, you need to re-run the AD plugin in case we make some changes to the libraries or schema.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dir_plugin/plug431.html#wp62839
no, unless you make changes to the AD and need to choose different OUs other than the ones already configured there is nothing to look out for or need to rerun the plugin
java
if this helps, please rate
java
www.cisco.com/go/pdi
Green
Community Member
Ok thanks for the replies.
I've compared the "component version" on this system of the AD plugin and that of another already upgraded system and they show the same version for that item. Would that indicate there is no need to re-run the plugin, or does that not really indicate of there have been any schema changes.
Green
You should be good then as long as everything is functioning normally.
110
