06-16-2010 10:52 AM - edited 03-15-2019 11:16 PM
What's the easiest way to get 4 digit dialing between to non-IP connected sites?
I know this can be done with translation patterns, but does the UC500 support Centrex lines or SIP trunks?
Thanks!
Solved! Go to Solution.
06-16-2010 11:34 AM
It supports all that. It is just matter of configuring it "right".
06-16-2010 11:34 AM
06-16-2010 11:43 AM
Thanks! Right now I needed to know if it is possible.
I'm sure I'll post more questions when I have to make it work.
06-17-2010 10:53 AM
You are welcome, thanks for the nice rating and good luck!
