4 digit to 7 digit dialiling
We have to one of site on Call Manager with 4 digit extension, we will be changing to 7 digit now.
GW is MGCP
Just want to check if we can expand digits on gateway, as i have read somewhere number expansion command does not work in MGCP gateway
we have extension mobility profile, what steps need to take care
call Manager 7
Dhiraj
Everyone's tags (3)
No, you need to to all digit manipulation on CUCM.
And whether you need to change something or not, depends on if the telco is also going to change the number of digits.
EM is no different than any DN on a phone, whatever you need to adjust in all the other DNs, might need to be changed in EM, that's pretty much up to you, and your dial plan.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Query can prefix 4 digit number?
or BAT is only option?
157
