4.x and 5.X AD Schema extension
Wanting to install Unity 5.x in same AD domain as 4.x is. Will the schema extensions done by 5.x, have any effect on the 4.x installation?
1 ACCEPTED SOLUTION
Re: 4.x and 5.X AD Schema extension
Hello Millward,
The schema extensions done by 5.x are backwards compatible with the 4.x installation, so it will not have a negative effect on the existing installation. It is ok to install the Unity 5.x in the same domain as the Unity 4.x installation.
See also:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cunetoptionsreqs.html#wp40670
Michael.
Hello Millward,
See also:
Michael.
Thanks for the quick response. this is exactly what I was looking for.
You're very welcome, Millward. Take care.
Michael.
448
